'72 4spd reverse lights
I thought I had my backup lights hooked up right until I noticed they are on all the time! I know the switch works fine because if I remove the rod and manually adjust the switch the lights will shut off.
Is it just the positiong of the switch that is messing me up?
Did you try swapping the wires on the switch?
EDIT OOPS! I missed the part about "shutting off manually"...nevermind
The post is only 3 1/2 lines long and I still mised a part.
