Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-06-2006, 09:03 PM   #1
JustinD
CF Senior Member
JustinD's Avatar
Default Misfire Problem
Ok, I've had a misfire for quite some time. I changed the spark plugs and wires. I've used a multi meter on all of those components and I still am having a problem. I tracked it down to cylinder #5. I unpluged the spark plug wire and it doesn't misfire anymore. You can just tell that it is missing that cylinder. So what would be my next plan of attaqck to get the mis out?
JustinD is offline   Reply With Quote
Old 08-06-2006, 09:13 PM   #2
JustinD
CF Senior Member
JustinD's Avatar
I just did a compression test on #5. I got 153 in 3 strokes. So I think that is good. My plug doesn't read when I ohm meter it and my wire going to that cylinder is 7.31 k ohm's.
Old 08-06-2006, 09:43 PM   #3
LT4Coupe
CF Senior Member
LT4Coupe's Avatar
What are you referring to as a misfire? I always thought of a misfire
as the air/fuel mixture not igniting....which would feel the same as
a plug wire being removed. But, you say it feels different with
the wire removed.
LT4Coupe is offline   Reply With Quote
Old 08-06-2006, 09:46 PM   #4
JustinD
CF Senior Member
JustinD's Avatar
It is like a ticking noise. Like it is detonating to soon or too late.
Old 08-06-2006, 09:48 PM   #5
dgruenke
CF Senior Member
dgruenke's Avatar
Quote:
Are you sure it's not an exhaust leak at the cylinder. An exhaust leak will sound like a tick.
dgruenke is offline   Reply With Quote
Old 08-06-2006, 09:59 PM   #6
JustinD
CF Senior Member
JustinD's Avatar
How would I check for that?
Old 08-06-2006, 10:10 PM   #7
gmviso
Junior Member
gmviso's Avatar
Is it possible that you have too much valve lash? That could account for the noise and would explain why the noise goes away when you remove the plug wire. If so, the adjustment for it is fairly easy, though messy. Might want to consider having a good mechanic do it if you have not done it before because you can over tighten the rocker arms and end up burning your valve seats.
gmviso is offline   Reply With Quote
Old 08-06-2006, 10:12 PM   #8
JustinD
CF Senior Member
JustinD's Avatar
It is possible. I adjusted them in the first place. With the motor running. What a mess, took forever to get the oil burnt off my header wrap.
Old 08-06-2006, 10:50 PM   #9
jdmick
CF Senior Member
jdmick's Avatar
Quote:
jdmick is offline   Reply With Quote
Old 08-06-2006, 10:58 PM   #10
JustinD
CF Senior Member
JustinD's Avatar
So, should I readjust that valve?
Old 08-06-2006, 11:02 PM   #11
...Roger...
CF Senior Member
...Roger...'s Avatar
Justin you should go back and readjust all of your valves the way 427 Hotrod told you to do it.Post #8 of the 888 posts !!!
...Roger... is offline   Reply With Quote
Old 08-06-2006, 11:14 PM   #12
JustinD
CF Senior Member
JustinD's Avatar
The valve was fine. Definatly wasn't to tight. The rest of the valves are good too.
Old 08-06-2006, 11:38 PM   #13
BarryK
CF Senior Member
BarryK's Avatar
try rerouting the #5 & #7 ignition wires. These two cylinders are adjacent to each other (obviously) but are also the only two cylinders that are consecutive in the firing order ( 1-8-4-3-6-5-7-2), this is known to be a problem at times on many cars. The spark from one wire affects the spark on the next pulse in the next wire.
BarryK is offline   Reply With Quote
Old 08-06-2006, 11:44 PM   #14
JustinD
CF Senior Member
JustinD's Avatar
So, you want me to move them away from eachother? They are all wireloomed up and not touching. But just to be safe, I can put them away from eachother. If this doesn't work do you have any other ideas of what it could be. I'm fresh out.
Old 08-06-2006, 11:55 PM   #15
BarryK
CF Senior Member
BarryK's Avatar
in the wire loom seperatoes they are also next to each other. at the least move the away from each other by changing their locations in the seperators and best case is to try to reroute both wires in some fashion to avoid as much as possible the #5 & #7 being close to each other. I know there are limitations how far you can keep the wires seperated but do what you can
Old 08-06-2006, 11:57 PM   #16
JustinD
CF Senior Member
JustinD's Avatar
Ok, I'll reroute them. But It is late to fire it up. What else could cause this ticking noise?
Old 08-07-2006, 12:23 AM   #17
BarryK
CF Senior Member
BarryK's Avatar
the wire moving is for the missing issue. don't have an answer for you on the ticking noise
Old 08-07-2006, 12:26 AM   #18
JustinD
CF Senior Member
JustinD's Avatar
Well, I'm assuming the ticking is the mis. Because it only happens when the spark plug wire is connected to the #5.
Old 08-07-2006, 09:12 AM   #19
terry82
CF Senior Member
take the rocker arms from that cylinder and reset on another clyinder ,see what you get ,if its still happens i would check the lift of the rockers it may be a long shot but it could be a ...cam .
terry82 is offline   Reply With Quote
Old 08-07-2006, 09:34 AM   #20
...Roger...
CF Senior Member
If you want to get rid of the tick and removing #5 does that -just leave the wire off !!!!! Sorry couldnt resist.Justin did you get the backfire problem fixed?-------- http://forums.corvetteforum.com/show....php?t=1410195
Reload this Page Misfire Problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stumble and misfire problem Monster231 C5 Tech 10 05-23-2005 11:01 AM
LT-1 Random misfire problem crkemppainen C4 Tech/Performance 15 01-21-2005 12:06 AM
Problem with Header install...PLEASE HELP spoiled996 C5 Tech 23 08-23-2004 01:39 PM
Happy Days! Finally running like a Raped Ape and Overheating Problem Also Fixed! Mopar Jimmy C5 Tech 24 08-06-2002 12:17 AM
Misfire in cylinder #7 ohonepewter C5 Tech 11 11-22-2001 01:24 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
