Tach circuit board 75
What does the circuit board on the back of the tach actually do?
Is it a frequency to voltage converter? If so does anyone know what voltages would be full range on the tach?
The reason I ask is if it is indeed a F to V converter then I will probably get rid of it and make my own. This would allow me to use a tach with a speedo face on it to make an electric speedo that would be run by the Vehicle Speed Sensor in the transmission.
CI 5 & 8 Veteran
Bullshark
Me 3 on the schematic.
I have schematics for the later versions which used an LM18919, but not the original circuit which used two IC's and discrete transistors.
As 70 LS1 suggested, the tach circuit is essentially a frequency to voltage convertor - actually its two F-V converter that are out of phase. (SIN and COSINE). I'm thinking the original circuits used two F to V chips, but I'd like to see the schematic.
If you want to build your own tach circuit, I would suggest using the CS8190.
You can buy them through Digikey - P.N. CS8190ENF16GOS-ND
What I need is to build an adjustable circuit that will drive the tach. That will allow me to use it as a speedometer and adjust it for different tire sizes and rear ratios.
"The CS8190 is specifically designed for use with air−core meter
movements. The IC provides all the functions necessary for an analog
tachometer or speedometer. The CS8190 takes a speed sensor input
and generates sine and cosine related output signals to differentially
drive an air−core meter."
CS8190
CS8190
CI 5 & 8 Veteran
CS8190
CS8190
The old GM design used two quad National Semiconductor op amps, The schematic doesn't call out the old obsolete IC part # and I forgot which one it was now. I would have to try to match it via the 14-pin DIP pinout. Probably not worth it since I have been told they are very hard to find.
I told Jeff I will try to scan the old schematic and PM you a copy, problem is it is in very small print and may be hard to read.
Bullshark
I received the schematic and can read it fine -
Thank you very much!
Its a good addition to my collection of tach info.
The footprint on this op-amp is just wierd - its no wonder replacement parts are hard to find.
The CS8190 should drive a 225 ohm coil with no problem.
However, its designed to drive both ends of both coils.
Thats 4 contact points as opposed to 3
A standard C3 tach has only 3 terminals.
One end of each coil is joined together into a common.
CI 5 & 8 Veteran
Bullshark
I think it may be easier to use a stock or replacement board and just modify the frequency coming from the PCM to calibrate it.
I actually think I can place a speedo face on a second tach and use the PCM to drive that as well.
CI 5 & 8 Veteran
I think you could use that, but you would have to take the outputs of the CS8190 and run them through another circui. The stock tach outputs are 0-10V where the two outputs fron the CS8190 go from -7V to +7V. Once you condition the signal, you should be able to tie the two (-)'s together and feed the tach.
Bullshark
