Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-30-2006, 09:17 PM   #1
SKIPPERS _1
Junior Member
Default Rear Spindle
HOW DO I REMOVE THE REAR SPINDLE ON A 68. I AM TRYING TO REPLACE THE EMERGENCY BRAKES.ALSO WHAT DOES THE ARM THAT THE CABLE ATTACHES TO ATTACH TO.
THE LAST OWNER DISCARDED THE REAR SHOES.
SKIPPERS _1 is offline   Reply With Quote
Old 07-30-2006, 09:21 PM   #2
...Roger...
CF Senior Member
...Roger...'s Avatar
You really should have a pusher(puller)or at least a driver that will protect t he threads on the spindle
...Roger... is offline   Reply With Quote
Old 07-30-2006, 10:00 PM   #3
GruntyPants
CF Senior Member
GruntyPants's Avatar
Send a message via AIM to GruntyPants Send a message via Yahoo to GruntyPants Send a message via Skype™ to GruntyPants
In order to do it properly, you will need to remove the trailing arm and press the spindle out. If they've been replaced with 'slip fit' races for the bearings, you may be able to drive them out with a drift or the like, but you risk seriously damaging the spindle. I have heard of ways to replace the parking brakes without removing the spindle, but there's a lot of cussing and throwing of tools. Do a search and you'll find several threads regarding parking brakes, and R and R of the trailing arm, spindle setups.
GruntyPants is offline   Reply With Quote
Old 07-30-2006, 10:28 PM   #4
wnjlt1
CF Senior Member
wnjlt1's Avatar
if you are going to remove the spindle with the trailing arm on the car you will need a special tool to drive the spindle out. if you have the entire trailing arm off the car, a press and some drivers in place would definately work.
Click the image to open in full size.
wnjlt1 is offline   Reply With Quote
Old 07-30-2006, 10:32 PM   #5
...Roger...
CF Senior Member
Now there is a pusher !!!!!!
Old 07-31-2006, 07:43 AM   #6
GTR1999
CF Senior Member
If you're just going to replace the shoes you do not need to remove the spindle. If you are going to remove the spindle then you're going to have to replace the bearings and now you have to be able to correctly set them up to .001-.002 endplay or you're going to create more problems. If you're not sure about this job check my posts on it, it will walk you through the job.
If the spindle had been in there 30 years and there is rust in the area those pushed tools are not too good. I have one and never use it and I rebuild these all the time. The tool may break the caliper bracket before it pops out the spindle,everyone is different.
Good luck,
Gary
GTR1999 is offline   Reply With Quote
Old 07-31-2006, 07:49 AM   #7
...Roger...
CF Senior Member
Good luck,
Gary
---gtr-what are you using-impact attachment?
Old 07-31-2006, 07:54 AM   #8
GTR1999
CF Senior Member
I don't remove the spindle while the arm is on the car. I work on the arm on the bench and use a 20 ton press to pop them off. Sometimes they go easy others seem like they're welded on!
Here's that post I have going.
http://forums.corvetteforum.com/show....php?t=1229686
Old 07-31-2006, 09:43 AM   #9
Hammerhead Fred
CF Senior Member
Hammerhead Fred's Avatar
You can rebuild the rear parking brakes w/o removing the spindle.
Most difficult part is getting the forward shoe onto the retaining pin but it can be done. If you search the forum you'll see some creative posts for performing this stunt. My favorite is using string to tie the spring into submission while you fit the retaining cup onto the pin then simply cutting the string.
The arm you mention (if I understand you correctly) is at the top. It's the lever that pushes the shoes apart. It doesn't "attach" to anything. It sits between the upper shoes and the spring pressure holds the lever arm in place (you really need a diagram but the emergency brake assembly is simply a miniture version of standard drum brakes). You can remove this arm for cleaning by carefully pushing off the retaining clip that is under the pivot pin where the longer arm (the one that holds the cable ball) attaches to the push arm (the one that prys against the shoe. Once the clip is off the pin will pull out and you can clean the arm so it moves easily when the brake is applied.
Hammerhead Fred is offline   Reply With Quote
Old 07-31-2006, 09:52 AM   #10
...Roger...
CF Senior Member
Nice post Gary ! I wish I could remove every one and rebuild it like that but my everyday drivers wallets couldnt take it !!! Thats alot of extra work for just a bearing problem.I have a full set of factory recommended Kent-Moore tools for this operation(30 years old) and maybe its just the quality of the tool but I have never bent or broken the caliper bracket and I've done a few(stopped counting at a 1000 setups).I used to have a supplier for a full faced tapered rotor shim but that dried up and then went to facing the spindle to rotor surface and then to replacing the spindle when I found I could buy an almost perfect spindle from International Axle Comp.for $95.(not for NCRS cars)(wheel flange max.runout .0005 and the machining center on nut end doesnt tweak when you torque it)I set up with "0" end play and end up with .002 with a short drive.Do you have an outlet for tapered shims?What was the pin Van Steel was cutting?Anyway fantastic post and its nice to see others doing it right !!!
Old 07-31-2006, 10:18 AM   #11
SKIPPERS _1
Junior Member
Thanks For The Tips, I Will Read More On It To Determine If I Can Handle It Without Removing The Spindle, I Hope So.
Thanks Again.
Rich
Old 07-31-2006, 10:45 AM   #12
...Roger...
CF Senior Member
Thanks Again.
Rich
Sorry Skipper we got off a little-If you dont have the tools to remove the bearings-yes you can do it without removing spindle.It takes some patience and this tool from Ecklers will help but it takes time getting use to using the tool also.#A2514
Old 08-15-2006, 07:39 AM   #13
...Roger...
CF Senior Member
Thanks Again.
Rich
Skipper-just curious how did you come out with this?Real PITA-Huh?
Old 08-15-2006, 07:01 PM   #14
SKIPPERS _1
Junior Member
I Gave Up For Now , The Corvette Show Ie Next Weekend And I Want To Drive The Car There.
It Looks Like I Will Take The Trailering Arm Off And Do It That Way.
You Know There Is Always Something Else It Will Need While Iam There.
Thanks To Everyone For The Help
Rick
Reload this Page Rear Spindle
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
