Ignition Points Adjustment Tool
Old 07-22-2006, 12:10 PM
Tom Johnson
Tom Johnson's Avatar
Default Ignition Points Adjustment Tool
Where can I purchase an ignition points adjustment tool?
Old 07-22-2006, 12:26 PM
Rockn-Roll
Rockn-Roll's Avatar
For a stock distributor you need a flat head screwdriver to adjust the points mount and a 1/8" allen wrench to adjust the dwell. You also need a dwell meter (set to about 30º) unless you want to use a points gap gauge (set to .019"). All of these tools are available at almost any parts store.
Old 07-22-2006, 12:33 PM
Tom Johnson
What I am looking for is a long flexible shaft screw driver with a 1/8" allen head on the end.
Old 07-22-2006, 01:10 PM
yellow 72
yellow 72's Avatar
St. Jude Donor '09
I have one that hasn't been used in years...PM me your address and it's your's
Old 07-22-2006, 01:58 PM
PRNDL
PRNDL's Avatar
I never knew such a thing existed. Is there any advantage over a regular little L-shaped allen wrench?
Old 07-22-2006, 02:00 PM
kaamacat
kaamacat's Avatar
Nice thing about the flex driver is, you can set it in there and know your not gonna get a shock. (btw, remember to re-check your timing once you have done the points)
Old 07-22-2006, 02:21 PM
mirrorfinishman
mirrorfinishman's Avatar
Here is the one I have got. Of course, like AJ Foyt would say, mine was handed down from my father to me.
http://www.kd-tools.com/2539.htm
Old 07-22-2006, 08:02 PM
Rockn-Roll
Rockn-Roll's Avatar
There's lots of stuff out there that only the professionals know about. Did you know that there are extra long screw drivers...about 4 feet long for adjusting the idle mixture and idle speed? I've got a pair that I've loaned out to a friend which really help on hot days when it's too painful to lean over a hot engine...I'd rather get my tan the old fashion way.
Old 07-22-2006, 08:17 PM
TopGunn
TopGunn's Avatar
I just bought one like this from NAPA, works for the carb and the distributer. About $12 I think.
Bill
Old 07-23-2006, 01:10 AM
terry82
terry82's Avatar
i would be carefull giving these tools away,100 years from now they will be worth a lot of cash on e-bay . even better if they had been used on vettes, hahahah
To Ignition Points Adjustment Tool
Quick Reply: Ignition Points Adjustment Tool
