idel on 1982 crossfire
Old 05-09-2006, 11:47 AM
kjscook
1st Gear
kjscook's Avatar
Default idel on 1982 crossfire
i am restoring 1982 vette crossfire. had the engine completely serviced.plugs, wires,rotor,throtlebodys and etc. i can not get the idle below 1200. adjusted th. bod. all the way slow. any advice?
Old 07-22-2006, 03:07 PM
JGVette
JGVette's Avatar
I had the same problem and swapped out the stock chip for a Hypertech. It also resolved the R700 problem with constant shifts in and out of overdrive.
Jay G
82 Vette
Old 07-22-2006, 03:55 PM
Roadster71
Roadster71's Avatar
Could be a vacum leak
Old 07-22-2006, 04:30 PM
SIXFOOTER
Support Corvetteforum!
SIXFOOTER's Avatar
Yep. that would be my first suspect. What was going on before you started on it?
Old 07-22-2006, 06:19 PM
C3Racing
C3Racing's Avatar
St. Jude Donor '07-'08
check for vacum leaks , and or your IAC motors are bad or sticking due to corbon build up on the pintle. Mine does this only sometimes but very rare , so JGVette might have good sugestion.
Old 07-22-2006, 07:56 PM
82 C.E.
82 C.E.'s Avatar
Try tighting your TB's and top plate first.
Old 07-22-2006, 10:28 PM
terry82
terry82's Avatar
the computer controls the idle .you have a vac leak
Old 07-23-2006, 12:01 AM
C3Racing
C3Racing's Avatar
Yes true ! but if the IAC's are inop or the pintle's (on the iac's) have corbon build up causing to stick to open or closed the ECM only does so much so if there is a vacum leak (you would hear it) or there is a sensor malf............................
Old 07-23-2006, 01:36 AM
MN-Brent
MN-Brent's Avatar
Most 82s with a high idle are associated to a vacuum leak.
You could also try to replace your ECM Coolent Temp Sensor located by your thermostat housing. This can go bad, tricking the ECM to believe it is cold and setting you up in high idle.
You could also try to set yourself up with the Win ALDL program, an old laptop PC, and an RS-232 to ALDL converter cable to monitor your ECM operation/sensors real time to see if there is anything going on.
check this out:
http://web.telia.com/~u60113744/soft...dl/winaldl.htm
To idel on 1982 crossfire
Quick Reply: idel on 1982 crossfire
