1980 rear brake rivets
I see lots of mention of drilling out rivets to remove the rear brake discs,but I cannot positively identify where these rivets are in order to do so. Can someone tell me how to know what to drill?
The only possibility I see is two flat areas about 3/8" deep located within the lug circle. They look more like the face of the axle then rivets; but I imagine this is them. Just do not want to accidentaly drill hole in the axle face.
Can anyone give me a way to know where these rivets are. Of course the manual is useless. Also what diameter drill?
They look like the back of a stud. Do you really need to resurface?
In order to begin the drilling process, you should think about starting out with about an 1/8 inch drill bit and then work your way up to the inside diameter of the rivet. Such as; 1/8, 1/4, 5/16 etc.
You will know when you have reached the inside diameter when you use a drill that is large enough(5/16", 3/8") to drill off the head of the rivet. At that point you should be able to knock thru the remaining portion of the rivet.
It is not a difficult process. It just takes time because you need to start out with a small drill bit and then work your way up in size. And of course, there are 5 rivets per ech rear wheel. So that means you will be drilling out a total of ten rivets.
Just take your time and once you get the first rivet out the remianing ones will get that much more easy.
