Door Linkage clip advice
I hope the link below helps, also if you look at the links at the bottom of the articles you can see that there sold seperately.
http://www.corvettemagazine.com/2005...dle/handle.asp
You only need a clip for the end of the threaded adjustment piece. The other end twists into place.
Here is a link from Ricks showing the clip you need. It is the DOR459 one in the picture (third from the left).
Thanks for the link, but I need stronger glasses to read it, can you make it bigger for us visually impared?
thanks, I will see if I can pick one up at GM in the morning.
I tried copying that picture for others to see but couldn't do it.
Do I need to remove the handle to put this on?
so you need two clips?
thx
In the process my son snapped the door lock rod clip, do you have a GM p/n for ecklers 23215 and 23216?
BTW I couldn't figure out how to install the door lock lever clip ( the lower one)
thx
thx
thx
thx
My hands are too big to fit in there but my 9 year old has the smarts and fingers to get it done. He gave which is rare but he did manage to install the linkage and adjsuted so it works with no binding, However he says the clip is useless. Go figure a 9 year old with attitude.
BTW how are you converting those part #s to GM #'s?
thx once again, I will try to convince him to put on the lower clip!
