Rear Suspension
Old 07-04-2006, 04:04 PM
HO-alts-Rick
HO-alts-Rick's Avatar
Default Rear Suspension
I need to raise the ride height of my 81 back up. I have a very large stereo system wieghing about 200lbs in the cargo area. How do I do this?
Old 07-04-2006, 04:36 PM
revel_inmy_loss
revel_inmy_loss's Avatar
tighten the bolts on both sides of the rear spring and then.... your done!
just make sure you tighten them even amounts (count your turns)
Old 07-04-2006, 09:45 PM
Tim_Ko
Tim_Ko's Avatar
It may not be easy to turn those bolts because of rust/scale/dirt on the threads. Clean the threads off with a wire brush, spray it with WD40, and use the technique - tighten a half-turn, loosen 1/4 turn ... tighten a half-turn, loosen a 1/4 turn. When using the wire brush, ... use a lot of elbow grease and it will make the wrenching a lot easier.
Old 07-04-2006, 10:42 PM
HO-alts-Rick
I only have one rear spring????I am confused, Anybody have pics of what bolt I need to tighten? Is it like torshion bar on a chrysler?
Old 07-04-2006, 10:47 PM
birdsmith
birdsmith's Avatar
That spring has a long bolt at either end which anchors the end of each trailing arm to it. By tightening those bolts you are pulling the back of the car UP. If you run out of threads you can get shorter bolts; just make sure they're Grade 8 minimum.
Old 07-05-2006, 10:09 AM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
At this point, before turning any wrenches, you should get a service manual and flip through it to at least gain a passing familiarity with how your car is put together...
Old 07-05-2006, 10:22 AM
mensch53
mensch53's Avatar
Read and understand before you even touch a wrench. I have been baffled by many a project before I got on here and asked the right questions. Search through the archives here for pictures of some nicely put together rear setups and that will help a lot in understanding what people are talking about. Look at the long bolt a few inches off the ground just inside each rear tire and it will start to make sense.
Old 07-05-2006, 04:25 PM
Bee Jay
Bee Jay's Avatar
200lbs sound system? This we gotta see. Can you post pictures?
Old 07-05-2006, 05:15 PM
Meh
Meh's Avatar
My friend had one of those. Finally divorced that biatch.
Old 07-05-2006, 05:26 PM
Bee Jay
Bee Jay's Avatar
Dude, that was funny.
Old 07-05-2006, 05:27 PM
Twin_Turbo
Twin_Turbo's Avatar
To Rear Suspension
Quick Reply: Rear Suspension
