Silla Radiators
Old 06-21-2006, 09:01 PM
Kalway
Kalway's Avatar
Default Silla Radiators
Anyone know anything about em? They come with a lifetime warranty and a 4 row heavy duty one is only ~$180
Old 06-21-2006, 09:34 PM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
Why not just go aluminum for about the same price?
Old 06-21-2006, 09:50 PM
Kalway
Kalway's Avatar
Find me a 4 row aluminum that will fit without issue for under $250, then.
Old 06-21-2006, 10:21 PM
...Roger...
...Roger...'s Avatar
What is the BTU rating?Does it compare to original?
Old 06-21-2006, 10:26 PM
Kalway
Kalway's Avatar
Heh the original is 25 years old. I would think ANYTHING new would be able to beat the original.
Old 06-21-2006, 10:37 PM
Meh
Meh's Avatar
Will it fit? That's the big question.
Old 06-21-2006, 10:39 PM
pef427
pef427's Avatar
Summit, Jeg's, etc...my local speedshop for $179. I then took it to a local radiator shop along with mine for a pattern and the rad. shop ordered a couple of aluminum necks and for $35 walla! It fits perfectly. It is 2 rows of 1" aluminum tubes. Make sure you get the fully welded one. No epoxy.
Old 06-21-2006, 10:41 PM
...Roger...
If the original was 3400 BTU and the "new" one is 3200 BTU then your going to fight to keep it cool.
Old 06-21-2006, 11:10 PM
Meh
Meh's Avatar
Old 06-21-2006, 11:24 PM
Glassbowtie77
Glassbowtie77's Avatar
I replaced mine with a Silla radiator, it fit perfectly and I have no cooling issues with it. I bought it off Ebay for $150. and free shipping.
Old 06-22-2006, 02:35 AM
Kalway
Kalway's Avatar
2 rows? The original is a 4 row, how can a 2 row aluminum radiator be more efficient than a 4 row copper/bronze?
Maybe a radiator expert can chime in here for me and explain why aluminum radiators cool better than copper/bronze ones. My experience with cooling is mainly with computers and the best cooling for CPUs is with copper. Copper has better heat transfer but takes a little more flow to keep it cool, while aluminum is quicker to cool off, but doesn't transfer heat as well. Silver is the fastest heat transferer but due to cost isn't really any benefit over copper.
Old 06-22-2006, 02:58 AM
Meh
Meh's Avatar
http://www.dewitts.com/pages/whyaluminum.asp
My copper/brass radiator did a good job cooling. When it sprung too many leaks to fix, I went with aluminum. It was very impressive how it would now just sit on 180 all day long no matter what.
Old 06-22-2006, 04:45 AM
Kalway
Kalway's Avatar
Makes pretty good sense. Can't make the tubes on a copper/brass radiator as wide due to weight. So they just use a bunch of small ones.
On there it mentions visteon only makes aluminum radiators. A visteon radiator at kragen is only $244... However there are no specs listed.
Old 06-22-2006, 05:47 AM
jerrylee
jerrylee's Avatar
A 2 row radiator has bigger tubes in it's cores...I believe the c/b uses a tube which is 3/8"--so 4 x .375=1.5"...........and the alum. radiator uses tubes which are 1"--so 2x1"=2"......................Also I believe c/b has a fin height of 1/2" as apposed to 3/8" for aluminum giving u more levels in it's core.....plus look at the C6-ZO6..GMinstalled a single row alum. to cool this bad boy.........
Old 06-22-2006, 07:23 AM
PhotoVette1
PhotoVette1's Avatar
Be careful with the cheap Chinese copper/brass radiators. If you look in them through the radiator cap hole, you'll notice that the internal welds are so bad that the coolant channels are almost half-filled with solder.
Old 06-22-2006, 09:54 AM
I'm Batman
I'm Batman's Avatar
St. Jude Donor '07
The Summit-brand aluminum radiator is made by Northern. Very nice piece of work, fully welded. Some speed shops might also have them - I got mine for a good price at a swap meet from a semi-local speed shop.
Old 06-22-2006, 10:12 AM
flood
flood's Avatar
if it fits perfectly as an above poster pointed out thats a pretty good deal.
The issue I always want to know is if its fits perfectly. YOu dont want to mess around with it for hours trying to get it to work. The cooling capacity is important too but if you aren't running anything with a ton of HP it won't be a huge deal.
Just as a side note, my alum cools much better than the original but its also WAAYYY lighter. The original copper brass are pretty heavy.
To Silla Radiators
Old 06-22-2006, 11:13 AM
Kalway
Kalway's Avatar
Quick note, I read some old forum posts about how some of the universal Aluminum radiators from like Northern fit without modification. Can anyone elaborate on this? If I can get a universal aluminum that will fit fine I'll take it.
Old 06-22-2006, 12:41 PM
...Roger...
Originally Posted by Tom DeWitt
My god, this is the second thead about one radiator. You've spent days researching all these different companies and have enough information to write a book on the subject. You're never going to spring for an aluminum radiator regardless of the price.
I'm sorry about the attitude, but it just amazes me how some Corvette owners can drop 5k into building engines and then become squeaky tight about cooling it down. There was a day when Corvette people wanted the best for there car, not the cheapest thing they could find.
Serious people buy parts, dreamers post threads
Old 06-22-2006, 01:07 PM
flood
flood's Avatar
I posted a thread, then bought your radiator!
thanks for that btw. The temp needle never gets above the thermostat temp
Quick Reply: Silla Radiators
