Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-19-2006, 08:02 AM   #1
Tele_Man
CF Senior Member
Tele_Man's Avatar
Send a message via MSN to Tele_Man
Default Draining the radiator without a mess?
I'm about to tackle the job of replacing the radiator and I was surveying the underside of the radiator yesterday to locate the drain plug. I found it without problem, but I noticed it is directly above a section of the front frame. I had hoped that I could simply place a drain pan under the plug to catch the coolant, but it looks like the coolant is going to splash on the frame and run all over the place.
Is there any clever way to drain the radiator without making a mess on the floor of my garage? Any of your tips and tricks would be appreciated. Thanks!
__________________
-TeleMan
1969 Coupe 427/390
Tele_Man is offline   Reply With Quote
Old 06-19-2006, 08:06 AM   #2
SIXFOOTER
CF Senior Member
Support Corvetteforum!
SIXFOOTER's Avatar
put a piece of hose on it and direct it down towards the drain pan
SIXFOOTER is offline   Reply With Quote
Old 06-19-2006, 08:56 AM   #3
...Roger...
CF Senior Member
...Roger...'s Avatar
I use a siphon method---a 2 foot piece of copper tube 3/8 dia.connected to a boat fuel squeeze bulb and a 3 foot piece of 3/8 rubber hose -put copper tube to bottom of radiator-put hose in bucket-squeeze bulb start siphon and presto no mess--most vettes have a plug in rad.and not petcock-another reason for this is so you dont tear the soldered in nut out of the bottom of radiator.
...Roger... is offline   Reply With Quote
Old 06-19-2006, 09:10 AM   #4
Tele_Man
CF Senior Member
Tele_Man's Avatar
I can confirm that there isn't a petcock on my radiator. It looks like a regular bolt and the last guy put teflon tape on the threads.
The boat fuel sounds like a clever idea, but my radiator cap is on the on the surge tank, not the radiator itself. So, I don't know how I would get the tubing down the radiator. (But I like that idea for syphoning the coolant out of the surge tank.)
Maybe I could duct tape a section of hose onto the end of a small plastic funnel, and then hold the funnel under the drain hole.
How much coolant should I expect to drain, i.e., how bid does my collection bucket have to be?
Old 06-19-2006, 09:18 AM   #5
ruby76
CF Senior Member
ruby76's Avatar
Location: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
I used a small hand pump. Place the "intake" tube down to the bottom of the radiator, start pumping till you hear slurping. Then wait a couple of minutes, and pump again (coolant will flow from engine to the radiator slowly). I didn't fill a 5 gallon bucket.
ruby76 is offline   Reply With Quote
Old 06-19-2006, 09:29 AM   #6
Tele_Man
CF Senior Member
Tele_Man's Avatar
How can I get a tube down the radiator?
Can I disconnect the inlet hose and shove a tube down to the bottom radiator through that opening?
Remember, on a '69 the radiator cap is on the surge tank, not the radiator itself.
Old 06-19-2006, 09:48 AM   #7
JPhil
CF Senior Member
Heck, my radiator doesn't even have a drain plug or a petcock-- nothing. I ended up removing the plugs on the engine block, one each side, down low in the middle, which drained the majority of coolant from the system. Then when I could finally access the bottom rad hose (this was on a rad removal job) I just had to loosen the hose and drain, oh probably a gallon, maybe not that much, into a bucket.
When I put it all back together I did put drain ***** in the block. That won't drain it all, but it'll be better than nothing....
John
JPhil is offline   Reply With Quote
Old 06-19-2006, 09:57 AM   #8
...Roger...
CF Senior Member
No you might damage tubes you have to use the bottom -unless someone else can think of another opening-I guess you could use a small plastic tube but dont force it
Old 06-19-2006, 09:59 AM   #9
RATT7
CF Senior Member
RATT7's Avatar
I have also used a hose, clamped it to the drain **** and this worked fine, very little spill or mess.
RATT7 is offline   Reply With Quote
Old 06-19-2006, 10:06 AM   #10
mdj21
CF Senior Member
mdj21's Avatar
my radiator didn't have a drain either, so i drilled a hole and brazed one it. much more convienent.
how about putting a funnel with a piece of tubing under your drain hole?
mdj21 is offline   Reply With Quote
Old 06-19-2006, 11:39 AM   #11
toyvet1
CF Senior Member
toyvet1's Avatar
Are you planning on replacing hoses.Why not just slit the lower hose over a bucket.
toyvet1 is offline   Reply With Quote
Old 06-19-2006, 11:51 AM   #12
mvftw
CF Senior Member
mvftw's Avatar
I start by going to the local A&P and getting cardboard and laying them flat. If you don't have 2 oil drain buckets get 1 or 2 deep turkey foil trays. Then I take off the water pump hose, it's easier to get to and less mess...
__________________
We do not stop playing because we grow old;
we grow old because we stop playing
mvftw is offline   Reply With Quote
Old 06-19-2006, 12:41 PM   #13
Tele_Man
CF Senior Member
Tele_Man's Avatar
Quote:
Well, I was planning to drain it and then fill it again will a flush solution, run the engine hot, and then drain it again.
Old 06-19-2006, 01:22 PM   #14
Fevre
CF Senior Member
Fevre's Avatar
Click the image to open in full size.
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
Got it as a gift, never used it for oil but use to drain all my rads.
Fevre is offline   Reply With Quote
Old 06-19-2006, 01:50 PM   #15
Tele_Man
CF Senior Member
Tele_Man's Avatar
Cool product, but it costs $100! I really don't need that contraption to help me change the oil on the Vette, and I surely don't expect to be changing the coolant frequently enough to justify that expense. But it is an interesting product.
Old 06-19-2006, 01:54 PM   #16
mensch53
CF Senior Member
mensch53's Avatar
Any reason you couldnt just pull the lower rad hose over a bucket? You dont have to cut it as long as it is not fused on there.
mensch53 is offline   Reply With Quote
Old 06-19-2006, 03:24 PM   #17
Tele_Man
CF Senior Member
Tele_Man's Avatar
Quote:
Theoretically, this would work. But opening a larger drain is going to cause a larger gush of coolant. One had better be quick with the hose and bucket.
I'll take a look under the car to see what the clearance is directly under the lower rad hose as it hooks up to the rad outlet. You may be right and there may be a clear passage to the bucket without splashing the frame.
Old 06-19-2006, 04:10 PM   #18
bs82vette
CF Senior Member
bs82vette's Avatar
Shop vac,tygon tubing and gallon pickle jar.
Drill two holes in lid of pickle jar for tygon tubing ,snug fit,run one end of tygon tubing in radiator,auto transmission tube,rear end or anything else you want to drain and other end in hole in lid.
Then use a second piece of tygon tubing in other hole in lid and put in hose on shop vacuum and seal with duct tape or make a wooded adapter plug.Turn on the vacuum and watch the jar fill.Turn off vacuum before liquid gets into tubing going to vacuum.
Using jar allows you to inspect condition of fluid.
If its anti-freeze or other non explosive fluid and you don't mind having the fluid in the vacuum hose and canister don't use the jar.
bs82vette is offline   Reply With Quote
Old 06-19-2006, 06:07 PM   #19
c69vete
CF Senior Member
Cruise-In VIII Veteran
St. Jude Donor '07
c69vete's Avatar
I just went thru this while preping my car for the Power tour. On the first drain there was not enough room to really catch the coolant and not cause a mess as, like you stated, the drain is directly over the frame. After the first drain, I removed the petcock and installed a 90 degree brass street Ellbow, 1/4 pipe thread into the rad. Then reinstall the petcock into the ellbow, pointing straight back. Now when you open the petcock, the coolant will flow into a bucket under the car with out hitting ANYTHING. You can expect about 2 1/2 gal of liquid if the system was full. By the way I am using a B-Cool alum. Rad.
c69vete is offline   Reply With Quote
Old 06-19-2006, 06:10 PM   #20
dosoctaves
CF Senior Member
St. Jude Donor '11-'12-'13
dosoctaves's Avatar
Pull the lower radiator hose over a bucket; with the front of the car jacked up...pull both the lower radiator hose and the heater return at the water pump...then you can easily reconnect and flush...
dosoctaves is offline   Reply With Quote
Reload this Page Draining the radiator without a mess?
Tags
drain, draining, fluid, making, mess, radiatir, radiator
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
