76 Vette, Smells like brake...but...Help...
Took the ole girl out tonight, pulled into gas station and smelled awful smell. Smelled like a brake pad. Driver side rear whell pretty hot, smelled pretty bad. Took it back home. Pop off the rear driver side wheel, which is hot(still hot after 30 minutes). Smells like break pad. Rotor is hot to touch. Look at pad...pad looks fine. Look at rotor...rotor looks fine. Spin the rotor...rotor spins fine.
Since the rotor seems to spin freely, I am at a loss as to why is it hot, and why does it smell like a burning brake pad. The calipers were all replaced about a year ago, as were the pads...and the rotors. Any idea whats going on here, and how to fix it?
Thanks in advance,
Mark
Thanks in advance,
Mark
OK then ....
Since I never use the parking brake, it is fairly safe to rule that out. As far as intermittent caliper hang up, whats the solution? Take it out and beat on the breaks for an hour to loosen them up?
I just had a similar problem on my 77 but the right front wheel. It turned out to be a clogged or swollen, over time, rubber brake line. The one connecting the caliper to the hardline. I didn't figure it out until the wheel was braking all of the time and I changed the pads and calipers. If when you did your brakes you didn't do the hoses as well this is where I would start. Pretty inexpensive to replace.
