How can I make a 250 pound rear spring.
#41
Originally Posted by Jclgodale3
BTW: Find all my post that demeans, critisizes, name calls, and breaks forum rules . I know the one in the race seat thread does.
#42
wow...you're even admitting to post under a new userID.... That's not very smart
Why didn't you just wait until the vacation is over ? Did you get banned ???
BTW, you're the only one on the forum who misspells becuase all the time...
#43
Originally Posted by Voetsek
So whats the funny part? The mcspeed part? You'll see.
#44
because because because of all the ignorant things he does lol. Sorry could not help it lol.
#45
#46
I sent a pm to the mod also. Yes I basically got banned for no reason though. It was for unappropriate picture which was not my fault that it was posted. If I got banned for something that I did I wouldn't be posting. And I do spell because wrong all the time.
#47
I missed the other thread, I've heard and read about it but I missed the picture ... I heard it was not female so I guess I didn't miss too much
That's why I knew it was you....
#48
I will add something good to this thread though if others might be interested. You can redrill the holes inboard as people have been doing this for a very long time mainly to increase the distance from the spring to the tire and not for increased spring rate. But by doing so you will increase the spring rate as well. I do not know by how many pounds as I have never sat down to figure it.
But if you are happy with the spring as is then it will make it just a bit stiffer. You can ask VBP and they will most likely have an answer for you on the change of the spring rate. As they also produce a shorter glass version as well.
#49
#50
Wonder why he isn't posting under his Yellow ID?
Well... now that he's posting under a new ID it may be lifetime vacation soon....
#51
He says he got banned - If my memory serves me right GDaina posted that two members are on vacation, nothing was said about lifetime vacation.
That is what Normally happens or an extended vacation lol. But who are we lol.
#53
If you do both sides the angle becomes too great. To move both holes you have to cut the spring just inside the existing holes and then drill 2 new 3/4 inch holes. This makes the spring too short with stock trialing arms. If you cut only 1 side, drill 1 new hole and then add a new 3/8th hole in the exact center the spring is shortened but at the same time the slope of the bolts is accetable.
I drove with a shortened spring for years but it bugged me that the bolts angled in. It really put a dent in the poly bushing and I did break a bolt once.
Later I offset the mounting on the trailing arms to fix this.
Drill only ONE side, not both
Drilling the hole doesn't really change the spring much. I did have a leaf spring checker and found my rear spring was 140 pounds per inch.
#55
#56
Originally Posted by turtlevette
Chris's threads sure are popular. 3 pages already.
At least he bumps my road course thread. The rest of you guys. :nojoy:
#58
How do these guys have 250# rates with 9 leafs then? I have offset trailing arms. Does that affect the mounting position?
#59
Originally Posted by mandm1200
Why not go to a sping shop and get one made? Making custom leaf springs should not be that big of a deal.
