Tach runs backwards...
What would cause this? It runs very smooth, just backwards, its cool to say I shift my stock c3 at (whats the last number?? 7?) like 7K, more if I feel like it, but its weird at the same time...
Any fixes, or just replace?
For an igniition system with breaker points check the following:
1. The - wire of the ignition coil must run to the distributor points.
2. The + wire of the ignition coil must be installed to one connection of the ignition switch.
3. The other connection of the ignition switch should run to the solenoid connection that also have connected a black wire that run to the + terminal of the battery.
4. The coil wire run (center wire from distributor cap) should run from distributor to center connection of the coil.
5. A second wire, also a + wire of the ignition coil should run to the oppose connection of solenoid described in item 3.
6. Check starter and battery grounds.
I have a '75 that does the same thing. No one here has been able to come up with a serious suggestion yet, and I have been asking for ages. If you get it fixed, I'd love to know what you found!!!
Thats about the only thing I can think of
This is a very strange problem and the first Ive ever heard of
St. Jude Donor '05, '09, '15
Originally Posted by Sky65
Never heard of that one before. Is the tach electronic or mechanical, stock or aftermarket, did it ever work correctly? Where does the needle sit with the engine off, zero or maxed out?
Thats a beautiful 65
St. Jude Donor '04 & '05
Good Luck!
St. Jude Donor '11-'12-'13,'19-'20
Per the Corvette black book, 1975 was the first year for HEI and electronic tac. My guess is that the TAC signal and ground wires are inverted.
Originally Posted by dosoctaves
..... My guess is that the TAC signal and ground wires are inverted.
If the tach is moving backwards then either the circuit board or the tach movement has an issue. The movement itself is capable is turning nearly 360 degrees, but normally the signal driving it wouldn't do so. The fact that it is points toward an issue with the board itself.
You can get a replacement board for $60-75, but often these don't work as well as they could. Another option is to have the original board repaired. That can usually be accomplished for about half this cost.
Hope this helps. Good Luck!
