How to tighten internal rear view mirror
Old 06-21-2023, 09:48 PM
Mpls Funk
Mpls Funk's Avatar
Default How to tighten internal rear view mirror
Hi all,
My rear view mirror (on windshield) is loose at the connection at the windshield (1970 coupe). The ball won't hold its position. I'm guessing there is some bracket or something that I can tighten to put more force/friction on that ball. But how do you get at it? Looks like thre is a black rubber (?) cover over it. How do you remove that? I don't want to just pull and pry and break something. I tried searching the forum, but didn't find an answer. Any help and/or pictures would be great!
thanks!
Old 06-21-2023, 11:08 PM
1967 Pedal Car Champion
Support Corvetteforum!
67:72's Avatar
Received 1,999 Likes on 1,351 Posts
As I recall, the side header vinyl trim pieces lay over long side tabs on the rubber mirror mount cover. Loosen the header trim and the cover should just pull off. Here's the detail from my '72 AIM. (I don't remember having to deal with all those components, so maybe most are behind the ball and bracket. I think you're just working with #10, 11, 12, & 13.) It's been a few years since I was in there... I seem to recall adding some thin leather to the cup where the ball sits. Just something to take up some space and add tension.
Old 06-23-2023, 07:05 AM
wwiiavfan
wwiiavfan's Avatar
One of the pieces is made of a crappy metal (cast?), and likes to break. I forget which one. I Bubba’d mine together with some adhesive and it’s holding- for now.
Old 06-23-2023, 07:07 AM
cottoneg
cottoneg's Avatar
I have the same issue. Watching this with much interest.
Old 06-23-2023, 08:19 AM
VERYSOON
VERYSOON's Avatar
I had this problem. I solved it by replacing the Phillips head screw with a flathead screw that takes an Allen wrench! A good, old-fashioned hardware store will have them. The rubber cover just pulls right out and has remained plyable after all these years. Mine is a 69.
VS
To How to tighten internal rear view mirror
Quick Reply: How to tighten internal rear view mirror
