Can You Clean And Reuse Fouled Plugs?
Old 04-17-2006, 11:14 PM
Ironcross
Ironcross's Avatar
I never priced any racing plugs as Champion always gave us several boxes of N54R`s as we needed them. This is a side electrode 3/4 reach plug that we used in all of our supercharged gas and fuel Chrysler engines. But i`m positive they were not $124.00 a set. In fact they always came in a box of ten, and every run a new set was used.
Old 04-17-2006, 11:36 PM
lucky76
lucky76's Avatar
This forum sucks sometimes. Let the guy clean his plugs if he wants to. An old vette may be a hobby but you don't have to spend all your money on it. Well maybe some do.
Old 04-17-2006, 11:37 PM
johnt365
johnt365's Avatar
you could clean them up and replace them. Or, you could do an engine swap and drop in a 427.
I mean, you already have your tools out. just put it on the visa card.
i agree lucky... fixing things and replacing parts are two totally different things.
Old 04-18-2006, 06:14 AM
theandies
theandies's Avatar
Originally Posted by 73L48 Dave
You can clean them by glass bead blasting. This is a standard maintenence procedure used on piston aircraft.
But automotive plugs are alot cheaper than aircraft plugs...I would just replace them.
Yup,
A&P mechanic here. We never replaced the plugs in a small piston aricraft engine unless it was damaged or had been in there for a long time. Of course a small piston aircraft engine has 2 spark plugs per cylinder and two ignition systems .
For the price we pay for automotive spark plugs, I'd say replace them.
Quick Reply: Can You Clean And Reuse Fouled Plugs?
