what spark plugs
Old 04-03-2006, 08:56 AM
palazzopl
palazzopl's Avatar
Default what spark plugs
I'm using Bosch plugs , with a edelbrock 600 cfm carb, have the carb leaned out as much as possible and it still runs rich.. I want to change the plugs to a hotter range.. What would be a good brand and number plug to use?
Old 04-04-2006, 11:03 PM
glen242
glen242's Avatar
Hotter than what? Changing plugs will not help a carb problem.
Old 04-05-2006, 10:55 AM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
Yea like Glen said, plugs are not going to cure a rich issue. Is the engine stock or modified? A 600 won't make you rich unless it's screwed up somehow.
Old 04-05-2006, 11:25 AM
mongo6901
mongo6901's Avatar
Plugs aren't the problem.
Old 04-05-2006, 01:59 PM
palazzopl
palazzopl's Avatar
its an 81 warranty engine 205 hp with a mild cam. all emmision junk off,edelbrock 600 carb and HEI distributer with a vacuum advance , ttiming set a 10 deg and 34 deg full advance. plugs are light tan at the tips but black at the base of the threads. exhaust pipes are sooty black
To what spark plugs
Quick Reply: what spark plugs
