Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-07-2006, 07:57 AM   #1
Grzenio
Junior Member
Grzenio's Avatar
Default Stingray AWD
Hi Guys
I`d like to know what do you think about our polish project to build the AWD C3 1979 Corvette . It will be equipped with LT1 stroker 388 engine with turbocharger. Transmisson is TH 400 with transbrake, the all powertrain is from GMC Typhoon, and the front part of the frame is from Typhoon with coilover suspension in all four corners. It will be the drag race car, specially build with the AWD powertrain , due to our very bad dragtrack surface.
Grzenio is offline   Reply With Quote
Old 03-07-2006, 08:03 AM   #2
enkeivette
CF Senior Member
enkeivette's Avatar
Wow, incredible. I would have gone with a manual trans and IRS to try to make a road racer, but you're building a drag car so Did you use the typhoon frame or just transfer stuff over? If so did you have to widen it?
enkeivette is offline   Reply With Quote
Old 03-07-2006, 08:28 AM   #3
Grzenio
Junior Member
Grzenio's Avatar
Typhoon`s front part of frame with all of the components (front differential carrier and IRS equipped with additional coilovers ) was directly weleded to the existing C3 Shark`s frame (as you can see on the attached pictures). After some modifications all is working perfectly.
The front frame fm Typhoon was not widen.The Typhoon`s wheel base is very wide itself, so if we would to widen the frame, the front wheels will be out of the C3 fenders.
Old 03-07-2006, 11:38 AM   #4
rentalcop79
Junior Member
rentalcop79's Avatar
That is by far the coolest mod I've ever seen. Forget the "C5 rear in a C3". Way to go.
rentalcop79 is offline   Reply With Quote
Old 03-07-2006, 11:54 AM   #5
Jims79
CF Senior Member
Jims79's Avatar
an AWD vette that still looks like a vette when the body is put back on I like it. Its something I wish chevy would do in the future.
Other sports car company's have AWD models why not a corvette?
Jims79 is offline   Reply With Quote
Old 03-07-2006, 11:58 AM   #6
Twin_Turbo
CF Senior Member
Awesome! looking forward to seeing more pics.
Twin_Turbo is offline   Reply With Quote
Old 03-07-2006, 12:12 PM   #7
b71vette
CF Senior Member
b71vette's Avatar
Send a message via AIM to b71vette
Default That is so cool
More Pics please
b71vette is offline   Reply With Quote
Old 03-07-2006, 12:20 PM   #8
Monty
CF Senior Member
Monty's Avatar
That's cool. I'd love to see more pics too, especially where the two frames are welded together.
Monty is offline   Reply With Quote
Old 03-07-2006, 12:35 PM   #9
bobs77vet
CF Senior Member
bobs77vet's Avatar
cool....keep the pictures coming....
bobs77vet is offline   Reply With Quote
Old 03-07-2006, 12:42 PM   #10
Grzenio
Junior Member
Grzenio's Avatar
The engine and body are not ready yet. Next pictures you will seen in about 2 weeks time.
Old 03-07-2006, 12:42 PM   #11
stingraymaniac
CF Senior Member
stingraymaniac's Avatar
wow that is nice!
more pics of the restoration of the frame please!
very cool
stingraymaniac is offline   Reply With Quote
Old 03-07-2006, 01:00 PM   #12
comp
CF Senior Member
comp's Avatar
Quote:
comp is offline   Reply With Quote
Old 03-07-2006, 01:31 PM   #13
Corey_68
CF Senior Member
Corey_68's Avatar
Sweet, keep us updated
Corey_68 is offline   Reply With Quote
Old 03-07-2006, 01:58 PM   #14
I'm Batman
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
I'm Batman's Avatar
Send a message via AIM to I'm Batman Send a message via Yahoo to I'm Batman
Ok, that's cool. I used to drive an AWD Eagle Talon - the AWD system hurt gas mileage a bit, but not bad. It was fun to drive, that thing would get traction on just about anything.
I'm Batman is offline   Reply With Quote
Old 03-07-2006, 01:59 PM   #15
77BuffaloVet
CF Senior Member
77BuffaloVet's Avatar
Send a message via AIM to 77BuffaloVet
that's amazing...more pictures when you have them!!!!!
77BuffaloVet is offline   Reply With Quote
Old 03-07-2006, 02:22 PM   #16
Solid LT1
CF Senior Member
Solid LT1's Avatar
Based on the performance of my Volkswagen Golf R32 daily driver, I give a BIG THUMBS UP! to AWD. I would have used a GMC/Chevy Astro van with the same differential for a parts donor if the turbo truck was still in good condition. The Astro van has the same center diff as the Syclone/Typhoon vehicles but isn't woth very much on the retail market. The little trucks use the same suspension components and the GM "Metric" mid-size cars of the late 70's early 80's and many circle track parts suppliers have "trick" components for them but, it looks like you have a pretty good set-up with the coil overs at the front although I would have left the Vette IRS in the back as it will hook-up better than the live axel your photos show. Good Luck on the project.
Solid LT1 is offline   Reply With Quote
Old 03-07-2006, 03:11 PM   #17
Grzenio
Junior Member
Grzenio's Avatar
More pics of the frame.
First weld.
Finish frame
This project is beeing made by VTG. One of the best Polish tuners. they also build quite fast Typhoon. More info of their cars You can find on http://www.vtg.pl/projekty.php or VTG TEAM
Old 03-07-2006, 04:09 PM   #18
burners
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
burners's Avatar
Well, that's pretty impressive. It should really move! I wonder what kind of power that transfer case can handle?
burners is offline   Reply With Quote
Old 03-07-2006, 04:10 PM   #19
evalu8r
CF Senior Member
evalu8r's Avatar
Cooool, but someone used a BFH on that tunnel to get the body into position.
Chris
evalu8r is offline   Reply With Quote
Old 03-07-2006, 04:22 PM   #20
lostpatrolman
CF Senior Member
lostpatrolman's Avatar
Send a message via AIM to lostpatrolman
Very interesting, but I wonder if you are going to have any problems with that extremely short driveshaft.
lostpatrolman is offline   Reply With Quote
Reload this Page Stingray AWD
Tags
1968, astro, awd, build, c3, c4, chevy, corvette, drag, forum, make, photos, poland, stingray, turbo, vette, vtg
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
'64 stingray? SynnersGirl C1 & C2 Corvettes 19 09-18-2002 08:00 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
