Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-19-2006, 04:48 PM   #1
JoeZ
CF Senior Member
JoeZ's Avatar
Send a message via ICQ to JoeZ
Default LS1 Swap - Side pipes possible?
Does anyone know of having side pipes on a C3 LS1 swap? My buddy is swapping one into his '75 right now and is curious about it.
Are there any custom headers that would fit, or would the entire assembly need to be custom for sidepipes? Any help would be appreciated...
Joe Z
JoeZ is offline   Reply With Quote
Old 02-19-2006, 04:48 PM   #2
enkeivette
CF Senior Member
enkeivette's Avatar
Custom... do a search on Nitrovette.
enkeivette is offline   Reply With Quote
Old 02-19-2006, 04:55 PM   #3
PatsLs1vette
CF Senior Member
PatsLs1vette's Avatar
yep i modified my hookers to fit,i bought ls1 header flanges from gm and cut my old flanges off and had to move 2 of the pipes on each side to fit the ls1 flanges.Took some time but works fine.The one pics shows how far they off from the start.
Click the image to open in full size.
__________________
73 vette chop top silver/navy blue metallic stripe LS6 .LS6 intake,hooker sidepipes modified,700r4,2400 stall,3.70 gears,17x9.5 boyds,autometer guages.flared quarters
2004 c5 blk/blk forged bottom end , ms3 cam,42lb injectors,59 cc patriot heads,92mm ported fast intake,vararam,3.73 gears,yank 4000 stall,dynatech
long tubes,modified z06 exhaust,petes flared quarters,rksport hood,18x12 black c6 z06 rims on 345/30/18 drag radials etc....422 rwhp
tuned by tune time performance
PatsLs1vette is offline   Reply With Quote
Old 02-19-2006, 05:04 PM   #4
Yellow73SB
CF Senior Member
St. Jude Donor '07
Looks great pat.
Yellow73SB is offline   Reply With Quote
Old 02-19-2006, 05:24 PM   #5
I'm Batman
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
I'm Batman's Avatar
Send a message via AIM to I'm Batman Send a message via Yahoo to I'm Batman
Great looking work. Something to keep in mind...if you get a stickler for an emissions tester, your car has to pass emissions for either the year of the body or the year of the engine, whichever is newer. That's at least the way it is in a lot of areas...
I'm Batman is offline   Reply With Quote
Old 02-19-2006, 05:24 PM   #6
vetteaddic
CF Senior Member
vetteaddic's Avatar
check stainlessworks they have a set for the c3 ls1
vetteaddic is offline   Reply With Quote
Old 02-19-2006, 06:09 PM   #7
Demonic Possession
CF Senior Member
Demonic Possession's Avatar
Pat, how do they sound?
Demonic Possession is offline   Reply With Quote
Old 02-19-2006, 06:34 PM   #8
PatsLs1vette
CF Senior Member
Ill be starting it tommorrow hopefully.
Old 02-19-2006, 06:37 PM   #9
Budman68
CF Senior Member
Cruise-In VII Veteran
St. Jude Donor '07
Budman68's Avatar
Send a message via AIM to Budman68
They are for the Newman frame and pretty darn pricey, but I'm sure nice.
Quote:
Budman68 is offline   Reply With Quote
Old 02-19-2006, 06:47 PM   #10
Demonic Possession
CF Senior Member
Quote:
Good Luck with it Tell us how it goes.
Old 02-19-2006, 06:49 PM   #11
PatsLs1vette
CF Senior Member
Ill be doing a video for sure of the start up,IF it starts.
Old 02-19-2006, 06:50 PM   #12
groovyjay
CF Senior Member
groovyjay's Avatar
Nice work pat! I like the idea of LSx w/ sidepipes!
groovyjay is offline   Reply With Quote
Old 02-19-2006, 09:35 PM   #13
JoeZ
CF Senior Member
JoeZ's Avatar
I'm in FL so emissions isn't a problem at all.
So Pat, you basically just took standard sbc headers and modified them to fit the LS1 if I understand you correctly?
Old 02-19-2006, 10:46 PM   #14
PatsLs1vette
CF Senior Member
yes i took hooker side pipes and cut off the stock flanges,2 of the pipes on each header have to be cut and moved to the spacing of the ls1 flanges.I also forgot on the drivers side sidepipe you have to cut the 4 tubes going under the frame as it exits out and lengthen them a bout 1 inch more so the sidetubes will fit outside the frame now next to the rocker panels.Passenger side is ok.
__________________
Old 02-19-2006, 11:00 PM   #15
71rdster
CF Senior Member
Custom LS1 headers to standard C3 exhaust location allows the use of Gm C3 sidepipes. Expensive, but still one of the most beautiful setups for C3 sidepipes.
71rdster is offline   Reply With Quote
Old 02-22-2006, 09:07 AM   #16
GDaina
CF Senior Member
GDaina's Avatar
Send a message via Yahoo to GDaina
http://www.mcjackscorvettes.com/McJacks_C3_Headers.htm Headers that bolt up to factory sidepipes...
GDaina is offline   Reply With Quote
Reload this Page LS1 Swap - Side pipes possible?
Tags
c3, conversion, corvette, flange, flanges, header, headers, ls, ls1, lsx, modify, pipe, pipes, side, sidepipe, sidepipes, swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
