78 trans am VS 76 vette
i have a 76 vette auto with an L82 only mods are k&N, headers and the original tips welded on to flowmasters. My friend have an all original 6.6 smokey and the bandit trans am,auto as well and he smokes the pants off of me all the time. The bad thing is is that he talks so much trash about my vette. Its time for me to start modding i have 3000 dollars to spend and i am interested in what you all think the best way to spend it to be able to our run him.
Carb, intake, cam, headers, torque converter, and rearend gears will wake that '76 right the hell up!
Originally Posted by redc3
heads. start with the heads. follow with cam and exhaust, carb/intake
the power is in the heads; either use yours with extensive machine work to make them flow, or buy a set of aluminum heads; i would go with a set of AFR heads;
add to that a MATHCED cam, headers, intake, and carb and the Bandit is done for.
should be able to do that for 3K if you do the work yourself. if you cant afford AFR heads, the l98 heads produce good horse power on the zz4s and should support 400 horsepower out of the box.
http://www.corvettefaq.com/gotvette.asp check out this link. i was steered to this site from the fourm. it will answer alot. i to have a sick 76 but worst it a L48. exhaust is the first thing for me. good luck
Pontiac tourque
The same mods head porting, cam, ect. to the Pontiac 400 it will again be kicking the Corvettes pants. The Pontiac tourque is hard to beat on the street. I'm a Pontiac guy to happens to be restoring a 68 Vette which I really like. But my GTO will run circles around the vette.
Agreed, if the Bandit decides to modify his original car. Then it becomes one-upsmanship and the guy with the most money will win.
true. the bandit can mod his 6.6; you can get a 383; then he can upgrade to a 455; then you can do a 502;
this game dont ever have to end; you can end up with a nitromethane blown big block as the end game, or better yet, strap some JATO units to the back of your vette.
thats part of the fun!
dont tell him you are going to mod.
Just tell him your car broke and it will be down for a bit. Then show up with all your mods.
Its a game, treat it like one.
I could have my friend in his Honda civic show up and make him look like a fool if you really want? THat always humbles people.
1. Send your carb to Lars for magic hammer tuning.
2. Recurve your distributor and set the timing according to Lars' paper.
3. True dual exhaust. Can't make power if the engine can't breath.
4. Good intake. Must have the above before this helps.
5. Good heads. Must have both of the above before this helps.
6. A cam that matches the heads and delievers power in the street band.
7. Can tinker with things like thinner gaskets and whatnot to change compression ratio.
8. Headers.
9. Stroke your L82 to a 406 mighty mouse.
8. Headers.
I have had both!
I owned a 78 TA with the 400 pontiac. I rebuilt the car, mostly stock with OK head work, used GTO heads and crank and a big cam. With a 4 spd and 3.42's it would smoke my Dad's '77 vette so bad. In fact it smoked most cars at the time. Later, years later I bought my 71 LS-5 thinking, "yeah BBC". However the somewhat stock 454, even with 3:55's would be no match for the old TA. Those cars are pretty tough if you put a little effort into the engine. Oh and they are easy to work on... no clearance issues like on a BB vette.
Still a vette's a 2 seater like a real sports car should be
carbster
carbster
