Power Steering Problems - HELP
My high pressure hose just went and I need to get it to the shop.
Can I drive it to the place or will I be doing damage? The thing turns but you have to be a he-man to turn the wheel when the car is stopped or near stop.
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Power Steering Problems - HELP (SuperFast80)
how far are you going to have to drive it ?
Remove the belt from the power steering pump and you will be able to drive as far as you need without damaging the rest of the system.
JIML82@aol.com
JIML82@aol.com
Re: Power Steering Problems - HELP (Jim Shea)
BSeery: I've got about 10 miles to go.
Jim: If I go without the belt. Is it driveable like a non-power setup? The reason I ask is that I face the prospect of leaving it at the shop for a 3 day long weekend (only in Canada;)). Can I take off the belt and keep it for the weekend?
The steering gear is the same power or manual steering. Your power steering set up is the same as manual steering with the tie rods in the "quick ratio" (shortest distance to the wheel centerline) steer arm holes. Therefore, except for some additional drag from the assist cylinder, your steering system will think it is manual steering. You won't hurt anything.
JIML82@aol.com
JIML82@aol.com
The weekend is back on!!!
You ARE sure right? :D I'm not doubting you, just double checking befor I do something imprudent.
SuperFast80
Agree w/ Jim. You could easily change the hose. I took the power st. pump off a car once when the hose failed. Less wt. & no problems.
:cheers:
:cheers:
Re: Power Steering Problems - HELP (Ganey)
Thanks guys. Just one question - would I be putting too much strain on the joint? I think it is a little worn and there is a little play.
The flexible coupling is the same, power or manual steering. That flexible coupling was designed to last over 100,000 miles under manual steering conditions. You won't hurt it. If it is worn you should replace it and check to make sure that the steering column is aligned to the steering gear when you install the new one. There is a mandatory assembly sequence for installing the steering column so that it is aligned properly to the steering gear. It is outlined in the Corvette AIM books and also in the Corvette shop manuals. I also can supply a copy.
JIML82@aol.com
JIML82@aol.com
