Rear Bearign Rebuild
Old 11-08-2005, 06:44 PM
GTR1999
GTR1999's Avatar
Received 2,710 Likes on 1,364 Posts
Default Rear Bearign Rebuild
gone
Old 11-08-2005, 06:47 PM
pauvil
pauvil's Avatar
Gary, how do you get the races out?, is there a tool, I would rather trust your method though.. Nice pics!
Thanks!!
Old 11-08-2005, 07:07 PM
goinbroke
goinbroke's Avatar
Great pics Gary. You found (gulp) .030" endplay at the spindle???....yikes.
Old 11-08-2005, 07:20 PM
mandm1200
Support Corvetteforum!
mandm1200's Avatar
Sure hope the rest of the car is in better condition! After seeing those bushing the owner may want someone to look at the front end as well.
Old 11-08-2005, 09:13 PM
Steve's74
Steve's74's Avatar
Originally Posted by gtr1999
The races in the housing are removed by hammer and drift. There are spots to hit the race and drive it out.
Here is the press setup I use
Gary,
I am getting ready to press my rear bearings apart and have the same press setup as you have. I'm curious how you managed to get those two plates in between the spindle and the bearing housing to press the two apart. I'm having trouble making that setup. Thanks.
Steve
Old 11-09-2005, 12:58 PM
Steve's74
Steve's74's Avatar
Steve, I strip the PB shoes out and always replace the backing plate so I can get the black plates under the plate and use a spindle knocker to protect the threads and press apart. This job the right came apart without much force build up and the left was so screwed up it came out as I was tapping off the spindle support.
Gary
Thanks Gary, that makes sense.
Steve
Old 11-09-2005, 04:55 PM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
Cut the pin out too. That will help.
Old 11-09-2005, 09:14 PM
goinbroke
goinbroke's Avatar
Gary, I've always been curious about something. Do you ever find the spindle journals to be slightly egged? Mine were close to half a thou egged to the plus side.....at least according to my bearing charts. The finishes were still near perfect......just egged....which is not terribly uncommon on a shaft ground between centers. Half a thou doesn't sound like much, but it essentially doubles the amount of interference on two sides of the journal.
Old 11-09-2005, 09:30 PM
SteveG75
SteveG75's Avatar
Hey Gary,
What do you get for a TA rebuild (assuming spindles are OK)? I may be interested in running mine down to you this spring. PM me if you want.
Thanks,
Old 11-10-2005, 08:51 AM
Steve's74
Steve's74's Avatar
Old 11-10-2005, 09:14 AM
comp
comp's Avatar
Worked on the arms today. removed the bushings, stripped, washed, and painted with Eastwoods rust encapsulator. This is the 1st time using the eastwood product,usually I use POR15.
Gary
so do you like the Eastwood stuff ???
Old 11-10-2005, 09:26 AM
Twin_Turbo
Twin_Turbo's Avatar
If you want to get the races out without a chance of damaging the housing use a tig welder and lay a bead on the race, it'll practically fall out. If you don't have tig but a mig it'll work too as long as you leave the housing a bit greasy to avoild splatter from sticking (or use anti splatter spray)
Old 11-12-2005, 10:15 PM
Kid Vette
Kid Vette's Avatar
Nice pics! Thanks for sharing.
Old 11-13-2005, 01:28 PM
Gordonm
Gordonm's Avatar
Here are the Right side parts cleaned and ready to set the end play and assemble.
Where does that saw blade go?
Old 11-13-2005, 01:44 PM
77vetteuk
77vetteuk's Avatar
I have never had one bearing set dialed in with the shim size in any of the kits. If I was doing this all the time all day long I'd have a full set of .001" increment shims in front of me to speed up things. Instead I final fit them using a surface grinder.
Had to do this with my shim kit to get it as close to the tight end of the factory end play tolorence.
Old 11-13-2005, 04:00 PM
pauvil
pauvil's Avatar
Gary, once you have your shims ready to go and press the inner bearing back on the spindle, how do you know when to stop? in other words is there a "feel" so you don't begin to crush the bearings??
Old 11-13-2005, 04:39 PM
Twin_Turbo
Twin_Turbo's Avatar
??? crush the bearings? That's what the spacers and shims are for, you set the bearing play when torqued to 100lbs.ft. The setup tool just mimics the spindle but it's slightly undersize so the bearings are a tight slip fit, this way you can disassemble it. If you then torque the whole deal down w/ the spindle in place the bearings are press fit on the spindle, when this is torqued down it's exactly the same as w/ the setup tool. The spacers determine the bearing end play, crush doesn't come into play here.
To Rear Bearign Rebuild
Old 11-13-2005, 05:00 PM
pauvil
pauvil's Avatar
Thanks TT, I was just thinking that when you press the bearing back over the spindle the bearing would run in to the races and put pressure on them, I wasn't thinking of the spacers, now I get it, I'm doing my first set and just didn't want to take any chances, sorry, stupid question.
Old 11-14-2005, 08:40 AM
Steve's74
Steve's74's Avatar
Steve I PM'd you some info this AM.
Gary
Hey Gary, I just saw this. I haven't recieved any PMs, might try again. I haven't found a free weekend to press my bearings apart. Hopefully, this weekend will work. Super nice write up, by the way. Leaves little to question.
Steve
Old 11-14-2005, 10:39 AM
jimvette999
jimvette999's Avatar
Default Easy Fix
Hey Gary....you should have used one of those bearing greasers. I read they can take care of play in the TA bearing assembly.
Nice work as usual
Jim
Quick Reply: Rear Bearign Rebuild
