Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-23-2005, 09:18 AM   #1
surfshark
CF Senior Member
surfshark's Avatar
Default Largest cam without changing valve springs?
I know I could call a supplier, but they do want to sell you stuff... What is the largest hydraulic camshaft that you can put in a 350 (041 heads) and not have to change/upgrade the valve springs? I want to keep it as simple and cheap as possible because I'll probably be selling the motor in several months. Thanks as always for your input.
surfshark is offline   Reply With Quote
Old 09-23-2005, 12:30 PM   #2
Nate '69
CF Senior Member
Nate '69's Avatar
Just go for a 210-218 duration cam @.050. Anything larger won't match the heads, intake gears etc. You'll have good torque.
Nate '69 is offline   Reply With Quote
Old 09-24-2005, 12:17 AM   #3
jackson
CF Senior Member
Quote:
If they're like the springs that came in the 041 head, the simple answer is no more than 0.480"-0.490" valve lift. If the springs are +20 years old, I wouldn't put a new higher-lift cam under them ... even though they might handle the lift when you measure for coil bind ... they are WEAK! ... and may break when running under the new stress! I'd pop for a new set of $25 "Z28" springs.
SpeedPro-SealedPower P/N VS739R
Howards Cams P/N 98214
Elgin P/N RV943X
For duration reference, stock L82 was 222/222.
Three good choices of hydraulic flat tappet cam & lifter kits are:
SpeedPro-SealedPower P/N KC1062R 0.468"/0.480" 220/231
Summit P/N SUM-K1105 0.465"/0.488" 224/234
Elgin P/N E1015 0.465"/0.488" 224/234 (cam only, no lifters)
Want a little less cam?
SpeedPro-SealedPower P/N CS1013R 0.443"/0.465" 214/224
Elgin P/N E1166 0.453"/0.480" 216/218 (cam only, no lifters)
jackson is offline   Reply With Quote
Old 09-24-2005, 01:04 AM   #4
surfshark
CF Senior Member
surfshark's Avatar
Thank you both for your advice. The heads were reconditioned by a local machine shop with new components and the motor only has 15,000 miles on it. It's been off the road for several years though.
Reload this Page Largest cam without changing valve springs?
Tags
bbc, big, c6, cam, changing, e1015, elgin, kit, largest, lift, lifter, springs, valve, valvesprings, whats
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
