Can't hit passing gear
I have a '73 auto and I am having trouble when flooring it. It doesn't run the best and won't hit pasing gear. The rest of the rang is running pretty smoothly, has a little trouble idling sometimes. The timing is right on, new plugs and wires. Any suggestions?
Nick
Nick
TH400 transmissions have an electric passing gear kick-down. The switch is activated by the gas pedal. The wiring goes to a connector on the drivers side of the transmission. Make sure it is plugged in. Make sure the fuse is good. Sometimes the gas pedal lever bends, and it won't activate the switch. G/L
Originally Posted by big_G
... Sometimes the gas pedal lever bends, and it won't activate the switch.
Here's how to check:
Disconnet the cowl switch (under the hood). With key in ignition, car not running, press the gas pedel all the way down. You should hear a very low click in the tranny (hard to hear if area is noisy). If the click is not there, the kick-down is not working. Either bend the pedal till it does, or compansate by putting tape on the switch....
Good Luck
It has become clear that at some time my TH 400 kickdown assy has been removed from my 71. Any suggestions on a replacement system? I belive it was removed with the idle control soilnoid system years ago.
Originally Posted by 71stockray
I sometimes have this same problem on my 71 and I do not have a electric kickdown switch. What is causing my TH 400 to do this?
What I am sayin is that there is a connection on the TH, but there is no switch on, or connected to the gas pedal or the accel cable linkage. Upon flooring the car it will ramp up in RPM and wind out unless I wait a second or let off the pedal than it will upshift.
1 Post
Here is his homepage, look under th400, no pics so you might have to e-mail him.
http://community-2.webtv.net/MATTGRU/
Originally Posted by desi
I had to put electric tape on the switch to make sure it was depressed completely....a common problem if you ask me.
Good Luck
Good Luck
Good luck.
i am having the same problem the guys that built my motor put in a 3000 stall tc and said that i did not need a kick down switch. this thing does nothing when i punch it but just high rev.
