A distributor story listen to Lars when he speaks....
1 Post
Cruise-In VIII Veteran
After an e-mail from Lars redirecting me a little, I pulled my distributor. I initially pulled it to replace the vacuum canister, do a little re-curve/test springs, learn some new stuff, and just generally inspect it.
These worn pins were just the tip of the ice burg. Im thinking that perhaps Ive discovered a problem. Ill let those that are interested know in a few after my new distributor gets here .
1 Post
i agree fxr...but whodathunk a worn out distrubutor?..
you'd think that it would be fine after only 25 years...
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,927 Likes
If you need a set of new pins, I have replacement weight pins that were machined and donated by a Forum member for use by Forum members. The pins are heat treated and of very good quality. You need to be able to un-braze the worn out pins and re-braze the new ones into place in order to use them. E-mail me if you want me to send you a pair. Since I have a finite quantity of these pins, please only request them if you're really going to use them...
V8FastCars@msn.com
V8FastCars@msn.com
1 Post
Originally Posted by SanDiegoPaul
You can replace the distributor shaft. Don't need a whole new dist.
And Lars, I sincerely appreciate the offer but am going to put in a new one..
