Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-31-2005, 07:50 AM   #1
Indynut
CF Senior Member
Indynut's Avatar
Default Starter wiring diagram
I have a '79 Corvette with a L-48 and I was wanting to look at a wiring diagram for the starter. However, I'm unable to locate one anywhere. Help please!!!
I had the starter off the other day and did a complete rebuild, but now something appears to be draining my battery. Just wanna make sure I've got it correct at the starter since I did have that off.
Thanks.
Indy
Indynut is offline   Reply With Quote
Old 08-31-2005, 08:40 AM   #2
wombvette
CF Senior Member
wombvette's Avatar
The purple wire goes on the inside small terminal. Any small pink wires go on the outside terminal, and any large terminal wires go on the large lug on the solinoid. Except, there is a black wire that is a ground and goes under the starter mounting bolt. This is the ground for the heater fan and wipers. Many times people mistakenly hook this to the solinoid and cause the drain that you refer to.
wombvette is offline   Reply With Quote
Old 08-31-2005, 09:34 AM   #3
Lorin D
CF Senior Member
Send a message via ICQ to Lorin D Send a message via AIM to Lorin D
Default Starter Wiring Diagram
I had the same problem. My wipers and defoster wouldn't work,
when we replaced the engine, the ground wire was connected to
the starer solenoid. My battery would drain.
Lorin D is offline   Reply With Quote
Reload this Page Starter wiring diagram
Tags
05, 1979, 2000, 79, c5, corvette, diagram, digrm, performance, purple, schematics, starter, vette, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
