Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-16-2005, 03:58 PM   #1
81fastvette
CF Senior Member
Default Steering Wheel moves itself when I hit a bump.
I am still trying to figure out what is wrong with the front end of my 81 with 192k on it. I think I have narrowed it down to possibly being the steering box. When I hit a speed bump with one tire doesn't matter which tire the steering wheel goes left to right. The harder I hit the bump the faster the steering wheel moves. The steering and handling feels funny when I hit a good dip in the road. The front end is tight and every thing is new within the last 4 years except for the steering box. Would like to get some input on this because I would hate to spend the money and time only to find out that well that wasn't it. Just replaced the idler arm to find out that that wasn't it.
81fastvette is offline   Reply With Quote
Old 08-16-2005, 05:34 PM   #2
Eddie 70
CF Senior Member
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
Eddie 70's Avatar
Have you checked the a arm bushings? These could be contributing to the problem. With 194k miles, it may be time to look at rebuilding the whole front suspension.
Eddie 70 is offline   Reply With Quote
Old 08-16-2005, 06:43 PM   #3
dath
CF Senior Member
dath's Avatar
I would think if the steering box were the problem that the wheels would move to one side or the other *WITHOUT* moving the steering wheel. I'd look elsewhere if your steering is tight. Bushings were a good suggestion.
dath is offline   Reply With Quote
Old 08-16-2005, 06:48 PM   #4
MEGALADON
CF Senior Member
MEGALADON's Avatar
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Park the car on a flat surface, while your looking under it, have one of your kids or wife, turn the wheel (while car is off) left to right, then you can see what worn out down there.
MEGALADON is offline   Reply With Quote
Old 08-16-2005, 07:13 PM   #5
VETTEVIC
CF Senior Member
VETTEVIC's Avatar
If your bushings are all "GOOD" then check your steering cylinder, seals may be going bad, or the dampening valves in the hydraulic actuator that the pump feeds. Anyway a cyl can be baught for under a hundred bucks and the parts stores in some areas carry them remanufactured.
VETTEVIC is offline   Reply With Quote
Old 08-16-2005, 07:47 PM   #6
Techno
CF Senior Member
Techno's Avatar
I have this same problem but over a choppy surface. The wheel wiggles right and left.
Except for my manual steering box the front end is all new.
I just thought it was frame flexing? That shouldn't be the case on yours though so mine might not be either... hope hope hope.
Techno is offline   Reply With Quote
Old 08-17-2005, 03:54 PM   #7
81fastvette
CF Senior Member
My front end is all fairly new also Except for the Steering Box which has 192k on it. The Steering wheel goes left to right regardless of which wheel hits a bump so it seems to me that it is in the steering system. Being as I just replaced the idler arm. That doesn't leave much else except for the box. I hate replacing things that don't need to be replaced. I was hoping to get a reply from someone who said they had the same problem and they had a fairly new front end and they replaced the box and that was the problem. I think I will try and adjust the lash on the steering box and see if that makes a difference. I can see the output shaft of the steering box move side to side a bit when laying under the car and rocking the shaft before the box. Doesn't anybody else have their steering wheel going side to side on speed bumps and bumpy roads?
Reload this Page Steering Wheel moves itself when I hit a bump.
Tags
bump, bumps, c4, car, corvette, hit, hits, hitting, left, move, moves, road, side, steering, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
