Holley ?: Effect of idle screw on transfer slot
Old 08-01-2005, 11:12 PM
Brettmc
Brettmc's Avatar
Originally Posted by Fevre
Yes the Proform does have replaceable idle air bleeds but if I increase their size would that not also lean out the transfers lot? The hesitation is just off idle at any speed or rpm. but only if I cruise or hold the throttle for a little bit at that position.
You can also decrease their size and richen up the idle but that should be a last resort.
I tore down the carb tonight and noticed a couple things, 2 of the throttle body to main body screws where a little loose and there are no power valve channel restriction openings in my sec meter block.
Loose screws sink ships. No PVCR? That's weird. I wonder if that's one of those metering blocks you get in secondary metering plate conversion kit?
Brett
Old 08-02-2005, 05:54 AM
Fevre
Fevre's Avatar
Brett
I am hoping that the loose screws are the problem, they where basically finger tight.
Yes that is weird, threaded hole but no where for the fuel to go. Put a plug in it and upped the jets, suprised I did not notice it before.
Old 08-02-2005, 09:41 AM
Brettmc
Brettmc's Avatar
Keep us posted.
Old 08-02-2005, 11:35 AM
Fevre
Fevre's Avatar
Keep us posted.
If you see a DP flying into orbit you will know it didn't fix it.
Old 10-17-2005, 09:15 AM
Fevre
Fevre's Avatar
Just a follow up for any that care, I decided to try my little 600 vac sec Holley and car now runs like a champ, guess sometimes you can have too big a carb. Wish I had a 650 dp to try out.
Quick Reply: Holley ?: Effect of idle screw on transfer slot
