(TH-400) Can you change the shift-linkage seal...
Old 07-16-2005, 08:33 PM
SkunkApe
SkunkApe's Avatar
Default (TH-400) Can you change the shift-linkage seal...
...without dropping the pan? I removed my exhaust today and got a close look at the area surrounding the shift linkage. It appears the seal around the shift shaft is leaking. Don't want to drop the pan (again). Can the seal be accessed/replaced from outside?
Old 07-16-2005, 08:54 PM
markdtn
markdtn's Avatar
No, you have to drop the pan to do it right. You could jam on another o-ring from the outside but I doubt it will help.
Old 07-16-2005, 09:17 PM
SkunkApe
SkunkApe's Avatar
Bummer...especially after I poured in a dozen quarts of TrickShift!
Old 07-16-2005, 10:20 PM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
I know that on most trannys you can replace the shift-shaft-seal easily. Never did one on my Turbo 400 though so he may be right.
Old 07-16-2005, 10:34 PM
big_G
big_G's Avatar
We have a small tool at the shop that will remove the shaft seal without dropping the pan. I think it will do 400's. Most tool jobbers (Snap-on, Matco, etc.) carry them on the truck. Better auto parts stores may also have them. G/L
Old 07-16-2005, 11:08 PM
7t2vette
The ORIGINAL and bestest
7t2vette's Avatar
Toronto Events Coordinator
Just did this. there is a tool which slides over the shaft and removes the seal from the outside.
Old 07-16-2005, 11:20 PM
big_G
big_G's Avatar
YEP!
Old 07-17-2005, 12:53 AM
SkunkApe
SkunkApe's Avatar
big_G
Is it a GM "special tool" or a generic thing that works on different seals?
Old 07-17-2005, 07:31 AM
7t2vette
7t2vette's Avatar
Dunno, took mine to a tranny shop for this.
Old 07-17-2005, 11:27 AM
SkunkApe
SkunkApe's Avatar
Found it in the Year One catalog...$34. Might not be worth it for a one-time use...
Old 07-17-2005, 11:50 AM
soggybottomboy
soggybottomboy's Avatar
Probably worth it if you factor the cost of the fluid you just poured. Plus you will have another tool and that's always a good thing.
Old 07-17-2005, 12:11 PM
SkunkApe
SkunkApe's Avatar
Probably not worth it to purchase the tool vs. taking it to a shop and having it done.
But, you're right. One can never have enough tools!
Old 07-17-2005, 01:06 PM
73 Vet
73 Vet's Avatar
What is the tool called? Part #?
Old 07-17-2005, 05:31 PM
73'Vette
73'Vette's Avatar
I don't have a part number for you, but I can vouch for the tool working. Try an internet search for TH400 shaft seal tool or something along those lines. It should be roughly 35-45 bucks.
Old 07-13-2011, 07:13 AM
baileylk
1st Gear
baileylk's Avatar
Default price
How much did it cost you to change the seal @ the shop? Thanks
Old 07-13-2011, 10:55 AM
AzMotorhead
AzMotorhead's Avatar
Snap-on tool PN#YA 9348 Transmission seal remover /installer.
Trans tool
To (TH-400) Can you change the shift-linkage seal...
Quick Reply: (TH-400) Can you change the shift-linkage seal...
