Lowering by Cutting Coils
Old 06-05-2005, 11:33 AM
7T3C3TTZ07
7T3C3TTZ07's Avatar
Default Lowering by Cutting Coils
I know this question has been answered by forum members before. At the time I was planning to lowe using a 550#(F41) spring. Now, I plan to go back to stock or maybe a 460# and want about 1" lower. I can't remember if the forum recommended 1/2 coil or a full coil to lower 1". BTW, I'm switching from polyurethane bushings to rubber. I was plagued by the squeak. No squeak when assembling and installing. "Lots of squeak" under load. I'll wait for the "in-place" greasable units that are made for hot rods.
Thanks, 73C3
Old 06-05-2005, 01:13 PM
rihwoods
rihwoods's Avatar
I cut half a coil off my original FE7 front springs,and that gave me 3/4"-1" drop. But check on the 550's,as you may obtain the same results without cutting,if I recall correctly...
Old 06-05-2005, 01:15 PM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
I used 550's and cut them 1/2 coil each. Ride height in front was 29" with the OEM springs, and now it is 27.5
Old 06-05-2005, 01:17 PM
MYBAD79
MYBAD79's Avatar
St. Jude Donor '05
The 550lbs springs are great with the Bilstein HD shocks. I did not cut these - see below:
Old 06-05-2005, 01:24 PM
Mike Mercury
Mike Mercury's Avatar
I didn't have that kinda luck on Yvonnes 1973 small block. I cut off 1/2 a coil and only got 3/8" lowering - and that was measured well after a settling-in period. And I triple checked that the coil was seating properly in the top pocket.
If I had to do it all over again, I would of cut-off one complete turn.
Old 06-05-2005, 02:14 PM
rihwoods
rihwoods's Avatar
I'm at 26.5" (245-60-15's) but I did it to original coils back in 1982....still have them and no measurement change...
Looks like your front end package worked out good...followed your posts on that...
Rich
Old 06-05-2005, 02:18 PM
rihwoods
rihwoods's Avatar
Assume you are talking of stock 15" wheels and all.....guess that could happen...at the time,I was running 255-60-15's.....on 245-60-15's now...
Old 06-05-2005, 05:39 PM
Mike Mercury
Old 06-05-2005, 08:37 PM
Red73
Red73's Avatar
I would only cut either a 1/2 coil or 1/4 until you reached your desired height. Taking a full coil may lower the car more than you desired. I've taken a 1 1/4 qtr off mine with 17" wheels. My car is pretty low and I wouldn't recommend it for a daily driver. Rod
Old 06-05-2005, 08:45 PM
Red73
Red73's Avatar
[img]http://forums.corvetteforum.com/photopost/data/1068/68272005_0512Image0038a-med.jpg
[/img]
Old 06-05-2005, 09:33 PM
MYBAD79
MYBAD79's Avatar
St. Jude Donor '05
[QUOTE=Red73]I would only cut either a 1/2 coil or 1/4 until you reached your desired height. Taking a full coil may lower the car more than you desired. I've taken a 1 1/4 qtr off mine with 17" wheels. My car is pretty low and I wouldn't recommend it for a daily driver. Rod
I agree, it's a little lower than the average C3
looks great !!!!
daily driver ??
Old 06-05-2005, 09:40 PM
73jst4fun
73jst4fun's Avatar
I just posted info on this, I put 460's in my 73, 350 sb with mods (aluminum heads, manifold, etc.) My front end was lightened about 90-100lbs., the coils measured 16 1/2" outside measurement with a cloth tape. First time I cut 9" off, tried it for a few days, was at 27 9/16", cut another 4" off ended up with 26 15/16" just right for my 245/6015 tires. Again the cutting depends on the weight/options/ mods you have done to the front end...
Old 06-05-2005, 10:06 PM
1971corvette
1971corvette's Avatar
YA ,read a few posts then ask
Old 06-05-2005, 10:52 PM
Jclgodale3
Jclgodale3's Avatar
my 71 small block with stock springs was @ 28" on the left and 28 1/4" on the right. I cut 1/2 coil from the top of the left and 1/2 coil + 1.5" from the right. Luckily...they both came out @ 26.5" on both sides. Lucky I guess on the first shot
Old 06-06-2005, 06:49 AM
Vesa
Vesa's Avatar
Seems like you assumed the frame was not level - one option is that only the body was not exacktly level even the frame was...
To Lowering by Cutting Coils
Quick Reply: Lowering by Cutting Coils
