You Guys With Richmond 6s....
Did you shorten the yoke? The directions for installing in C3s from Richmond recommends shortening the yoke to 3" from the original approximately 3.5". Nobody's mentioned doing that, and strangely the longer 3.5" yoke seems to safely slip full-length into the tranny without contacting anything, so I'm wondering if it's necessary to shorten it.
What yoke are you talking about?
Bob
I thought I was going to have to do this also. Interesting.
I bought the TH-400 one (short one with caps) and was going to cut mine as per their instructions. I haven't slipped it in yet and recently thought I saw that Richmond is now selling one (yoke) specifically tailored for our application (shortened). I was going to put the stock GM one in the other car and just buy that one they have if it had caps. I had a special HD (Heavy Duty) ROD built and their tech people were very knowledgable. A simple call to them should square things. I am not looking at the tranny as I type this, but I think that something simple like the speedo plastic gear thing was the problem (interference). I will look at the instructions when I get home. Those instructions were detailed as to why you had to cut the yoke and if it was the speedo gear, then without it- the yoke without cutting could be installed. Also the shifter handle for me that came with it is ridiculously "long". I was planning to buy the short straight one that they have from Summit.
Yoke 3930827
I have the yoke with the above number. I initially installed as it is built. Since I have this annoying noise in neutral at idle; I went ahead and trimmed about 1/2" off it.....didn't make any difference. I also took the tranny out and tore it apart to take a look inside before I changed that yoke.
The length of the yoke doesn't seem to matter; I couldn't see that it had done any damage whatsoever.
And I still have that annoying noise ....
And just to verify...
I have the yoke out of the old Borg Warner 4-speed ('75). Is that a TH400 yoke? It slips into the 6-speed just fine (26 splines).
