How to maintain Half Shaft geometry?
After lowering the rear of my car, I found that the halfshafts weren't parallel anymore. Instead, they were pointing up. I then raised my car an 1" in the back to get the half shafts parallel. I'd like to know how i can bring my car down an inch, and still keep my halfshafts parallel? Is there a de arched spring VBP can make? Any suggestions? Thanks.
The spring has nothing to do with 1/2 shaft alignment. It simply means your car is too low for the fixed housing.
How racers overcome this is by raising the housing an inch higher up . This takes a modified crossmember that allows the housing to sit up higher and a modified front mount.
Originally Posted by 427V8
I've heard that you can remove the rubber dushings from the diff crossmember to gain another inch.
but I imagine it would become very noisy!
Originally Posted by Redshark6974
that doesn't sound like an easy fix..
If you want it right then that is the way to go.
Again springs have nothing to do with this. You could just adjust your car higher so the 1/2 shafts are parallel to the ground or put up with the increased angle on the universals.
the easy way to move the diff up in the car is to remove the rubber and plate over the hole, then your rearend crossmember bolts directly to the frame......or in the case of my car we built a new (lightweight) crossmember out of square tubing. Until you cut those two crossmembers out of a car you have no idea how much they weight.
....redvetracr
PS: I have a real nice factory crossmember that has been plated if anyone reading this is interested (e-mail DIRECT!! redvetracr@msn.com)
....redvetracr
To a fabricator it is easy. Pulling the rearend is the hard part, not making a knotch in the crossmember.
I had planned that on days at the track or dyno, i'd just get down and raise the bolts...takes me like 5 minutes anyways.
Thanks for info on the spring.....what would the increased angle on the universals do? especially not really getting on it, no burnouts, or such...only normal driving around town.
For normal driving it shouldn't hurt.
C6 the C5 of tomorrow
....redvetracr
....redvetracr
BigBlockk
Later.....
Originally Posted by BigBlockk
Run tires that are two inches shorter.
BigBlockk
Later.....
BigBlockk
Later.....
BigBlockk
Later.....
BigBlockk
Later.....
I never said anything about it looking right but it will lower the car by 1". Personally I don't think anything under 27" diameter LOOKS right. Also, I don't think a little bit of an angle to the half shafts is a problem.
BigBlockk
Later.....
BigBlockk
Later.....
I ran some 40 series tires on 17" wheels for a while and they looked pretty stupid even with max lowering. I'm back to a 50 series with about 26.5" diam. Looks better, rides better.
If I was doing it I would knotch the crossmember. The stock crossmember is about 2 inches thick and hollow. The rearend bolts to the bottom with bolts accessed through a hole in the upper part of the crossmember. If you built a knotch in the crossmember to move the bottom of this crossmember up, a recess that the rearend sat in you would still have the rubber mount on the ends but the crossmember would sit 1 inch higher.
Will raising the differential have any adverse effect on the driveshaft? What about the strut rods? Will the bracket have to lowered?
Any pics of the lightweight crossmember??
Originally Posted by mandm1200
Nice easy solution. Gotta get me a welder and some steel.
