Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-23-2005, 02:05 PM   #1
1972vettman
CF Senior Member
1972vettman's Avatar
Default 1972 ignition switch change.......
I recently had to replace the ignition switch and the guy that installed the switch said that there was a gear with teeth in the steering column that needed to be replaced as well. Once he installed the switch he showed me how it was sticking and that there would be a problem getting the car to start because there would be no electrical current to the starter once the ignition switch was turned . My question is, does anyone know about this gear and how big of a job it is to replace ? I've done some research through books and on the web and i can't find anything. I even found a breakdown of the steering column and don't see any mention of this gear nor it being worn causing starting problems . I have had the starter and solenoid checked and they are good, the battery is charged, the ignition switch is just spinning and there is no power via the ignition to turn the starter. I'm beginning to wonder if the locksmith knew what he was doing. How big/exstensive of a job is it to replace the switch? Let me know your thoughts.
1972vettman is offline   Reply With Quote
Old 04-23-2005, 03:28 PM   #2
Jim Shea
CF Senior Member
Support Corvetteforum!
Jim Shea's Avatar
I have complete instructions on replacing your ignition switch and id you have to, the plastic sector gear. It makes a difference if you have a T&T column or if you have a standard non-adjustable. The T&T is just a bit more complicated.
On the T&T, if you replace the sector you might just as well replace the little die cast rack that the sector mates to. The rack is usually the thing that breaks.
It will be best if you pull the steering column out of the car and place the column in a vise in order to have more room to work.
You will need instructions 1,2,& 3 along with the pictures 1,2,& 3 that go with the instructions. (Again either T&T or standard). There are also blowup drawings as well.
They are all posted at www.corvettefaq.com in the Steering Section.
I am sure that we can walk you through the column and switch repair if you have the time.
Jim Shea
Jim Shea is offline   Reply With Quote
Reload this Page 1972 ignition switch change.......
Tags
1972, 72, c3, ca, carrier, corvette, died, ignition, james, jimmy, mail, remove, replace, shea, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
