Need hood clearance to carb What hood
Hey guys, Im running a Team G Weind intake I looked thru the intake runners and see that my ports don`t match with the 230 Dart alum heads, the ports are higher than the intake,so im thinking of getting the Dart intake to match the heads andI know Im going to have clearance issues with the stock hood (73 vet), Right now I have a 14 x 4 with drop base air lid, Here`s the question I have , will a L88 aftermarket hood give me the clearance im after? THANKS
CI 7-8 Veteran
Why not just get a 3" filter? I've seen many tests done on filter sizes and the results showed that the best gains where from the type of filter (oiled vs cheap paper, etc) and from the shape of the lower filter base.
I have a friend that has that setup and I think you will have to use a really small air cleaner....
________________________________________ _____________
