Carpet / Seat Belts
Carpet / Seat Belts
My install of new interior is finally coming together. Despite trying to note how the old materials were installed...I am now stumped. How does the lower seat belt pass through the new carpeting? I cannot remember. I would hate to just cut a hole. There is a rolled edge on the (plastic?) seat belt cover in the floor but I do not know how to mate with the carpet.
Does any of this make sense?
A photo or any advice would be greatly appreciated.
Bill
Bill
Paul:
Thanks for the input. Cutting from the back of the carpet is a good idea and probably would not be as visible as cutting from the side near the sill plate.
Bill
Bill
The seat belt comes out the side by the sill. You place the plastic cover over the seat belt retractor and there is a metal bracket that bolts to the sill. The seat belt passes through this wire bracket. The new carpet then lays over the plastic cover the passes right next to the sill plate through a missing piece of carpet, the rest of the edge is attached to the side of the sill. The actual sill plate just fits over the edge of the carpet. NO need to cut the carpet for the seat belt.
I just did my new carpet a month ago and it easily passed between the edge of the carpet and the sill plate.
Originally Posted by norvalwilhelm
The new carpet then lays over the plastic cover .
Eddie
That's it!! The cover was over the carpet. Concerning the metal brackets / guides...my car does not have them, and looks as if they were never installed. Checked the AIM and it certainly shows the devices.
Thanks, again
Bill
Thanks, again
Bill
Originally Posted by Silvr77
Interesting Norval. I have recarpeted two original cars (72 & 77) and both retractor covers were OVER the carpet. I wonder if original installation was different at some point.
Eddie
Eddie
You can do it any way you want but the appearance to me is better if the covers are hidden under the capet.
I installed new carpets a month or two ago and it worked out , no cutting of the carpet required and put the covers under the carpet, the side brackets on the sill and the belt fit between the new carpet and the sill plate.
