Heat Riser Question..
What is the downside of removing the Heat Riser on my '78 ? It is not driven in cold temperatures.
I am installing side pipes. I am not using headers, but coming off the stock exhaust manifold.
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I don't think it will be a major problem, but the car will take longer to warm up. You do need either a heat riser valve or adapter on the right side manifold though, I don't think you will be able to make a connection there without one or the other.
