Hose going into air filter
Old 02-19-2005, 02:15 PM
samsonb
samsonb's Avatar
Old 02-19-2005, 02:20 PM
AlwaysWave
AlwaysWave's Avatar
Cruise-In III Veteran
I think 2 possibilities.
1-it's the intake for the PCV system. You can put an open element breather in the valve cover.
2-it's the vacuum hose for the power brake booster which you need. If so it should plug on the manifold or carb base.
Old 02-19-2005, 02:27 PM
AlwaysWave
AlwaysWave's Avatar
okkkkkkkkk.....next thought is the vent hose from the gas tank fume thingie that's located below the master cylinder on the inner fender. If that's right, you do want it plugged into vacuum.
Old 02-19-2005, 02:29 PM
djcwardog
djcwardog's Avatar
I wonder if it is a hose coming from your charcoal canister up to the air filter or to the carb (needing a vacuum port in that case...) Time to look at an accurate vacuum hose diagram for your car...
Old 02-19-2005, 02:40 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
Josh,
Can you post a picture? There are miles of vacuum hoses on the '81 and vary in necesity from trivial (cruise control) to vital (power brake). Your loose hose is probably one of these.
Old 02-19-2005, 03:05 PM
Twin_Turbo
Twin_Turbo's Avatar
the hose you speak of is a vacuum hose, it conencts to the thermostatic vacuum switch for the thermac valve in the snorkel.
Old 02-19-2005, 03:13 PM
77Dream
77Dream's Avatar
I agree, sounds like you are describing charcoal canister line. But need to see pics to be sure.
Old 02-20-2005, 08:45 PM
carl a
carl a's Avatar
Originally Posted by joshwilson3
Sorry, can't post pics as I sold my digital camera. I will look around the net for any pics.
This hose isn't attached to a vacuum source, just plugs into the base of the filter housing. I could just leave it unplugged if I wanted to. I'm guessing that it is drawing in filtered air for some reason. Anyone know where to get a vacuum hose diagram for my car?
thanks
digital camera is a good tool around here, i use mine here quite a bit
Old 02-20-2005, 09:32 PM
luerja
luerja's Avatar
Josh, Josh, Josh....
If you can ....try and start posting some pics on your questions... I am sure your going to post often with your new "to you" corvette and i am willing to give you everything I have to make your corvette run better. but to get accurate answers to your questions you might have to start taking some pictures and posting your situation your in?
Many Thanks,
Jim
Old 02-20-2005, 10:04 PM
FB#1
FB#1's Avatar
Most of the open element air filters have a plastic elbow included, that bolts to the base plate, for you to plug the hose into. You simply punch out a pre-formed area that the elbow bolts to. Check to see if the one your looking at has it.
Old 02-21-2005, 05:09 AM
Pauld
Pauld's Avatar
There's your answer right there.
To Hose going into air filter
Quick Reply: Hose going into air filter
