Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-19-2005, 02:15 PM   #1
samsonb
CF Senior Member
samsonb is online now   Reply With Quote
Old 02-19-2005, 02:20 PM   #2
AlwaysWave
CF Senior Member
Cruise-In III Veteran
AlwaysWave's Avatar
I think 2 possibilities.
1-it's the intake for the PCV system. You can put an open element breather in the valve cover.
2-it's the vacuum hose for the power brake booster which you need. If so it should plug on the manifold or carb base.
__________________
Hot Rod Power Tour 98-99-03-04
Stars & Stripes Across America 2002
..................Hers.................. ................................Mine.... .....
AlwaysWave is offline   Reply With Quote
Old 02-19-2005, 02:27 PM   #3
AlwaysWave
CF Senior Member
AlwaysWave's Avatar
okkkkkkkkk.....next thought is the vent hose from the gas tank fume thingie that's located below the master cylinder on the inner fender. If that's right, you do want it plugged into vacuum.
Old 02-19-2005, 02:29 PM   #4
djcwardog
CF Senior Member
I wonder if it is a hose coming from your charcoal canister up to the air filter or to the carb (needing a vacuum port in that case...) Time to look at an accurate vacuum hose diagram for your car...
djcwardog is offline   Reply With Quote
Old 02-19-2005, 02:40 PM   #5
CA-Legal-Vette
CF Senior Member
CA-Legal-Vette's Avatar
Josh,
Can you post a picture? There are miles of vacuum hoses on the '81 and vary in necesity from trivial (cruise control) to vital (power brake). Your loose hose is probably one of these.
CA-Legal-Vette is offline   Reply With Quote
Old 02-19-2005, 03:05 PM   #6
Twin_Turbo
CF Senior Member
the hose you speak of is a vacuum hose, it conencts to the thermostatic vacuum switch for the thermac valve in the snorkel.
Twin_Turbo is offline   Reply With Quote
Old 02-19-2005, 03:13 PM   #7
77Dream
CF Senior Member
77Dream's Avatar
Quote:
I agree, sounds like you are describing charcoal canister line. But need to see pics to be sure.
77Dream is offline   Reply With Quote
Old 02-20-2005, 08:45 PM   #8
carl a
CF Senior Member
carl a's Avatar
Quote:
Originally Posted by joshwilson3
Sorry, can't post pics as I sold my digital camera. I will look around the net for any pics.
This hose isn't attached to a vacuum source, just plugs into the base of the filter housing. I could just leave it unplugged if I wanted to. I'm guessing that it is drawing in filtered air for some reason. Anyone know where to get a vacuum hose diagram for my car?
thanks
digital camera is a good tool around here, i use mine here quite a bit
__________________
carl a is offline   Reply With Quote
Old 02-20-2005, 09:32 PM   #9
luerja
CF Senior Member
luerja's Avatar
Send a message via Yahoo to luerja
Josh, Josh, Josh....
If you can ....try and start posting some pics on your questions... I am sure your going to post often with your new "to you" corvette and i am willing to give you everything I have to make your corvette run better. but to get accurate answers to your questions you might have to start taking some pictures and posting your situation your in?
Many Thanks,
Jim
luerja is offline   Reply With Quote
Old 02-20-2005, 10:04 PM   #10
FB#1
CF Senior Member
FB#1's Avatar
Most of the open element air filters have a plastic elbow included, that bolts to the base plate, for you to plug the hose into. You simply punch out a pre-formed area that the elbow bolts to. Check to see if the one your looking at has it.
FB#1 is offline   Reply With Quote
Old 02-21-2005, 05:09 AM   #11
Pauld
CF Senior Member
Pauld's Avatar
Quote:
There's your answer right there.
Pauld is offline   Reply With Quote
Reload this Page Hose going into air filter
Tags
1973, air, attached, carburater, cleaner, connections, corvette, eliminate, filter, hose, hoses, housing, thermac, vacuum, whats, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
