Shipping a transmission.. Where can I get a approprate shipping box/crate?
Old 02-12-2005, 09:53 AM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Shipping a transmission.. Where can I get a approprate shipping box/crate?
I haven't found the right crate for my TKO which I want to ship ASAP.. What type of place could have a crate/box that would hold up to the weight of the tranny (110 lbs or so)???
I want to ship Fedex. They accept up to 150 lbs, so, including the box/crate, I should still be below 150 lbs..
Old 02-12-2005, 10:03 AM
GDaina
Support Corvetteforum!
GDaina's Avatar
Here's where to get a crate: Lumber Yard, circular saw, tape rule, Screws....some assembly required...
Old 02-12-2005, 10:05 AM
GrandSportC3
That shipping cost would get expensive if I'd have to buy a circular saw just to ship the tranny... I have no need for one otherwise...
I just thought of something.. Maybe Home Depot would cut it for me if I buy the wood there..
Old 02-12-2005, 10:08 AM
GDaina
GDaina's Avatar
That they will, or find a used pallet and strap the tranny to the pallet...
Old 02-12-2005, 10:25 AM
shoptek
shoptek's Avatar
Dont you still have the crate from your new tranny??
Old 02-12-2005, 10:33 AM
Schmucker
Schmucker's Avatar
And you call yourself a man?
Maybe you can cut it with your dremel.
Old 02-12-2005, 10:38 AM
GrandSportC3
I have the pallet..Received the tranny on that pallet, but I don't think that Fedex would allow me to ship on a pallet??
The tranny that I received came by truck freight...
Old 02-12-2005, 10:39 AM
GrandSportC3
I have a pallet.. Don't think that FedEx will ship it on a pallet...
Old 02-12-2005, 10:51 AM
GDaina
GDaina's Avatar
How much does the tranny weigh? Think FedEx and UPS have a weigh limit, so your only option may be the truck
Old 02-12-2005, 10:55 AM
GrandSportC3
The tranny only has about 110 lbs and the FedEx weight limit is 150 lbs..
Old 02-12-2005, 11:42 AM
Twin_Turbo
Twin_Turbo's Avatar
Old 02-12-2005, 11:50 AM
theandies
theandies's Avatar
I sent my Diff to Van Steel in a cardboard box. It was a heavy duty box and I lined the bottom with another box that I cut to fit the bottom. The weight was right at around 90 pounds. The box worked great. I packed it with a lot of newspaper and the rest of the box I cut up to line the bottom. I'd call FedEx or UPS and see if you can use the pallet. Then you can find a box and attach it over the tranny/pallet. I see shipping boxes like that all the time at work.
Old 02-12-2005, 11:52 AM
WESCH
WESCH's Avatar
Hi
Keisler send the TKO500 in a cartoon box by UPS overseas. Actually very thick cartoon, but the tranny was still damaged. One attachment bolt lug was dented and cracked.
I would also only considder a wooden box.
I will see my T56 the 15th Feb when I visit Seattle. Will let you know how it was crated by D&DPerformance for 200 USD shipping/handling charges from MI to WA .
Gunther
Old 02-12-2005, 02:40 PM
82Vette'ster
82Vette'ster's Avatar
Around here Home Depot gives you on cut free and other cuts are 50 cents each. Design up a box made from a 4x8 sheet of 3/8's plywood and 1x2 or 2x2's on the corner edges. Glue and nail the tranny coffin together. I'm assuming you don't have a VSR drill for screws either.
Old 02-12-2005, 02:57 PM
GrandSportC3
I decided to make a crate myself with a regular saw.. It's a lot of work but I can do it...
Old 02-12-2005, 03:40 PM
Brown78
Brown78's Avatar
Oliver, Have Home Depot cut to fit. Make sure you have all the numbers right, before the cutting begins. Frame it with 1x1, and screw the tranny down to a 2x4 top and bottem to keep from moving around. Use 1/4" plywood for the skin. Use screws only. No nails. My TKO came from Keisler in a heavy duty card board box straped to a peace of 1/4" plywood in the box.
Old 02-12-2005, 04:11 PM
Mr. Wonderful
Mr. Wonderful's Avatar
Location: Slower than a speeding bullet................ Fort Lauderdale, FL
I was just at Publix, and I saw a bunch of nice heavy-duty banana boxes
That should be within your budget
To Shipping a transmission.. Where can I get a approprate shipping box/crate?
Old 02-12-2005, 04:34 PM
redvetracr
redvetracr's Avatar
Oliver, Are you anywhere near Jacksonville?? I just sent C/F member Dennis Hendrix a trans in a HS box....
....................redvetracr
Old 02-12-2005, 04:40 PM
GrandSportC3
Jacksonville is a 3.5 hour drive from here
Old 02-12-2005, 04:43 PM
GrandSportC3
Got a 14.4 Volt electric screwdriver..
Quick Reply: Shipping a transmission.. Where can I get a approprate shipping box/crate?
