Stripping is done, How hard is it to change the rear bumper
Well I got the stripping finished Sat, I had thought about using chemical stripper, but I had a razor blade laying around so I tried it for a WTH kinda thing. It worked great, way easier than I thought it would be and no drippy mess to deal with. Get this, it only took me a total of 11 hrs to do it! and that was with beer breaks! I was quoted a price of $1800 just to strip it I have a couple of cracks at the rear drivers fender that need fixing where a tire blew out on the previous owner, but besides that the rest of it is in very good shape.
I'm going to change out the urathane rear bumper to a fiberglass one because the top of the spoiler is very wavy (unless someone knows how to fix this)
So how hard is it to do? Will I need a new mounting kit? If you've done this before I would appreciate your thoughts or recomendations on this.
I'll try to take some pics and post them
have not replaced bumpers yet ,they dont look too hard to do .i am going to buy the truflex bumpers .they are less ridged .should be easier to match up to the body .i was told to get the new mounting kit .you saved $1800.00 stripping the car your self thats great .your labor rate down there must be high . how much does he want to paint the car ?
No new mounting kit required if you can remove all the nuts from the mounting strips without breaking the little studs, so remove the bumper first to see how it goes. The mounting strips are pop riveted so can be easily removed.
There is 1 long mounting strip across the top and 2 on the sides that follow the body contour. However, theré's also 2 little studs behind the back up lights (or was it the brake lights... can't remember exactly) that thread into the bumper, if you forget to remove those removing the bumper will be impossible
There's also a tab under the license plate that secures the the bottom of the bumper so it doesn't wobble.
The fiberglass ones probably don't have the holes for those 2 studs behind the lamps and this tab is also not present..well it's not on mine anyway.
Mine also did not have the mounting buckets for the rear lamps and there were no holes either, I had to punch them myself and shape it w/ a router to get the lamps in.
Razor Blade ?
Eddie:
Could you expound a little on the razor blade strip process?
For the life of me, I cannot understand how this can be done without damaging the underlying fiberglass. Do you use one of those blade "holders"? Any help appreciated.
Bill
Bill
Originally Posted by mox 77
Eddie:
Bill
Bill
Eddie:
Bill
Bill
I did it w/ a blade also, you can buy a handle to hold the blades but I did some experimenting and found that a long nose vise grip works best, held upside down you get a real shallow angle of attack and a minimal chance of digging into the glass.
Ok here is some pics and the tool that I used. I still have some spots at the bottom to strip but I think I am going to sand these areas, they are hard to get with the razor. The short stiffer holder with heavier blades worked better on the larger sections. the yellw scraper with thinner blades worked better on the curvier parts of the body.
Eddie:
Bill
Bill
Originally Posted by KALAWAY
How do you evenly use a razor blade and not dig too deep a time or two? I can't peel an apple or a potato without doing just that. Maybe it's just me.
