Rear speakers
Rear speakers
I have a 1978 with 6x9 rear speakers floating around the back. How have you all attached rear speakers?
Like factory
BarrelCurve (03-02-2024)
[QUOTE=interpon;1607576820]Like factory
I agree, but have to wonder if the factory mounts will take 6X9's with a large, heavy magnet. They don't seem all that sturdy.
Bikespace (03-01-2024)
pretty sure they are 6x9?
here is a link with a few links in it..
https://www.corvetteforum.com/forums...-speakers.html
I assumed he was talking about aftermarket 6X9's. OP should elaborate. Factory speakers then for sure the stock mounts.
@interpon posted his direct factory replacement 10 Ohm speakers.
One of my cars came with a set of 6" round speakers on a custom plywood mount. Nothing I've seen indicated that aftermarket 6x9s would fit in the stock location. But perhaps a template made from the stock mount, and built up a bit, would provide the clearance needed.
St. Jude Donor '22
mine needed a little space outward.
the diameter of magnet and over all speaker thickness were just too
much for the stock area.
I just shimmed the speaker surround/plate, board out.
looks fine.
looks fine.
[QUOTE=RickM Z06;1607576855]
It isn't if the speaker mount could support a 6X9" heavy magnet speaker, but its how big of a speaker magnet can fit between the speaker mount. After looking at aftermarket speakers specifications, I found Rockford Fosgate R169X2 had the smallest magnets. But even those were a shoehorn fit.
The following 4 users liked this post by kanvasman:
BarrelCurve (03-02-2024),
Fly skids up! (03-02-2024),
Rescue Rogers (03-02-2024),
Tranz Zam (03-02-2024)
