1977 "Moon Roof" top panels
I recently purchased a set of used "Moon Roof" t-top panels. I need to repaint them to match my 1973 Coupe. The interior hardware and the weatherstripping is in bad shape and I want to replace that after stripping and painting the tops. Two Questions: 1) Since these tops were offered in the 1977 year model, what version (early or late) of t-top weatherstripping do I order? I am assuming the same weatherstripping as for the standard t-top panels are used. If I am assuming wrong, please let me know. 2) the interior hardware is rusty and I want to replace it. Do I order the Front Pin, the Center Tabs (and screws), the locking latches for the 1977 application or the 1973 application (my car)? Any help on this is greatly appreciated. Thanks.
Jwtvette (01-26-2024)
Thanks bruiser. Very helpful information. Would you be willing to share any pictures you have of both the interior and exterior sides of your Moon Roof tops? I want to make sure I'm restoring them as close to "factory OEM" as possible.
Thank you so much for responding.
Chances are if they're older tops, what you have are Moon Roofs once made by a company called Saratoga Tops, but they could also be Thompson Astro tops or some other brand since there have been a few different makers of Corvette "glass" tops over the years. Some of these top makers used GM rubber and hardware while others came up with their own ways of attaching and sealing the tops.
It's pretty easy to tell which weatherstrip you need (as long as the tops you have originally used OEM rubber). The 69 first design - 77 t-top rubber uses 19 plastic push pins and requires a metal retainer to attach the weatherstrip over the door glass. The second design 77-82 t-top weatherstrip has 18 push pins and a piece of metal molded into the rubber where it meets the door glass, eliminating the need for the retainer strip.
A couple pictures of the underside of the tops you have might help identify what you need.
Last edited by gbvette62; 01-28-2024 at 10:08 AM. Reason: corrected punctuation positioning
interpon (01-28-2024)
