Front brakes
Front brakes
This is on 1981,I’m putting new pads on fronts,and putting O rings in calipers,as they still have seals in them,guestion is working on passenger side and I only took two springs off,in other words just half caliper,shouldn’t their be four springs,or the springs are just on the one half. Thanks
mark79,80 (01-15-2024)
4 springs
someone probably forgot to put in.
A nice write up
https://www.corvettemagazine.com/196...d-replacement/
A nice write up
Dementer sole survivor
Received 6,368 Likes
2016 C3 of Year Finalist
No directions from the supplier? My CSSBINC kit came with new everything, all i reused was the caliper shells themselves
Bikespace (01-15-2024)
The CSSB Inc. kit may cost a bit more, but it comes with new pistons, and springs, Buy the high-heat version if you go that route.
https://www.cssbinc.com/corvette-bra...rsion-kit.aspx
[QUOTE=Bikespace;1607430408]The CSSB Inc. kit may cost a bit more, but it comes with new pistons, and springs, Buy the high-heat version if you go that route.
https://www.cssbinc.com/corvette-bra...rsion-kit.aspx[/QUOTE
Don’t buy the red silicone o-ring ( high temp) kit if you want to use silicone fluid. It will fail quickly. The regular kit will probably be ok with silicone fluid despite the warrantee warnings.
interpon (01-15-2024)
Received 4,570 Likes
Cruise-In VIII Veteran
[/QUOTE
Don’t buy the red silicone o-ring ( high temp) kit if you want to use silicone fluid. It will fail quickly. The regular kit will probably be ok with silicone fluid despite the warrantee warnings.[/QUOTE]
Nope, it's not. I went down to the bearing and seal shop and purchased new O rings that are compatible with Dot 5. (Viton, which doesn't like Dot3 or4) I used their pistons, just purchased different O rings. I ran a thread on this , I think less than a year ago. I like my DOT 5.
Yea,according to the assembly manual,it says use a little silicone at bottom of piston in groove,which I guess why at the bottom of the calipers looked like jell after all these years.
[/QUOTE
Hi.
Did you also replace the seals in the master cylinder for the conversion to DOT5 ? Unfortunately, I can't find your thread.
Brgds
Try this link.
https://www.corvetteforum.com/forums...conundrum.html
The master cylinder, and most brake parts on most every car out there have no trouble with DOT 3,4 Or 5.
most all rubber brake parts are made of EPDM type rubber. The makers of these O ring caliper kits wanted O rings that didn't have the seam on the outer edge. Look at the ones in your O ring kit. The moulding seam is about 20 - 25 degrees off the outer and inner edge. In order to have these O rings made this way. They obviously went offshore. And the rubber is a compromise. It is fine for use with Dot 3. But not tolerant of silicone.
Try this link.
If your O-ring kit manufacturer tells you not to use DOT 5, don't. If you then source alternate O-rings to try to find something that is DOT 5 compatible, you are doing so at your own risk, but that thread has some information to get you started. I'll keep using the new O-rings, DOT 4 fluid, and doing periodic fluid changes.
4-vettes (01-16-2024)
Buying your own o-rings to replace the ones in the kits is a good idea. The best o-rings for DOT5 silicone fluid are peroxide cured EPDM. You can buy them from theoringstore.com for $1.67 each for the larger front pistons. The alternative is regular sulfur cured EPDM. They are half the price but have a lower temperature resistance. I think reputable master cylinder kits use regular EPDM seals which will be OK with silicone fluid since the master cylinder has no heat issues.
