Hood Grille Nuts
Hood Grille Nuts
I’m trying to find a set of ‘73-‘76 hood grille nuts (GM part no. 9420621) NOS or good used. They have rubber cushion inserts on the underside. I haven’t come across any repros and the replacements sold by the usual suppliers are acorn nuts that look nothing like the correct part. Here’s what the originals look like:
Any tips would be much appreciated.
This is probably the closest you will find for new.
https://www.ebay.com/itm/13304752752...Cclp%3A4429486
L8T2 (12-01-2023)
L8T2 (12-02-2023)
Very close. They are described as “thread cutting” and are to be used with “smooth studs”. I’ll take a look at the studs on my hood and see if the threads on them appear to have been cut by the nuts when they were installed. If they are a standard thread — say 3/16-20 — then these nuts might not work. But I’m betting they will. Thanks for finding these, and thanks for introducing the term “thread-cutting nuts” to my vocabulary.
A trick I learned is to set the nut over the stud, then turn it counterclockwise (lefty) slowly applying slight pressure. You will feel a click. This is the threads lining up with the nut. Slowly start to tighten. If there is little resistance, you’re following the existing cut threads. If not, you’re cutting new ones.
this has worked for me multiple times.
L8T2 (12-02-2023)
I’m not an authority (NCRS judges feel free to weigh in here), but I believe that you may lose originality points for using acorn nuts under strict judging if the thread cutters turn out to be the right part. Anybody out there have a completely untouched original ‘73-‘76 and care to comment?
You are buying one (1) NEW assortment. This assortment contains forty five (45) (see sizes below) zinc plated thread cutting nuts with mastic sealer that can be used on Buick, Cadillac, Chevrolet, Oldsmobile, Pontiac & GMC vehicles.
Mastic sealer it is.
If you are the original owner and your car has never been repainted, that’s a really helpful input. Otherwise there’s no way to know if your acorns are original without some more authoritative info. I’m not sure that this minor detail is worth anymore back-and-forth. As Bob Dylan sang, “you go your way and I’ll go mine.”
According to Section 8 "Hood and Vent Grille" on page 77 of the 2018 3rd edition NCRS 1973-1974 Corvette Technical Information Manual and Judging Guide, "Six (6) black phosphate-plated acorn nuts secure the underside of the grille". Fig. E 8.1 on the same page shows them.
Fran Giacoma
Fran Giacoma
Tooch1 (12-11-2023)
Fran Giacoma
Fran Giacoma
L8T2 (02-04-2024)
