Radio antenna cable for 78 w/power antenna
Have any of you needed to replace yours and if so, what did you use? Every vendor I looked at sells the cable for 78 fixed antenna only and other years/applications. Nobody appears to carry 78 w/power antenna cable. Guessing the fitting that screws onto the antenna is different. I also see lengths of 129" to 160".
Replacing my power antenna assembly and the cable in there now has a crude splice on it. Want to replace the cable but hitting roadblocks. Thanks all.
RickM
RickM
I'm not aware of anyone selling or making the antenna cable for 78-82 power antennas. The difference in them is that the power antenna cable has a nut that threads onto a fitting on the antenna, while the fixed mast antenna has the antenna body that the antenna mast goes into attached to the end of the cable. They are not interchangeable, and none of the earlier cables will work either.
I may have an NOS one. I have at least one because I know I saved for my 81 (and that ones not for sale), but I might still have one or two others. I'll try to take a look, but it will probably be a couple days before I can.
RickM Z06 (10-23-2023)
RickM
RickM
post 35 is the advice i got on my early 79 which is a 78 one year only
https://www.corvetteforum.com/forums...-wiring-2.html
RickM Z06 (10-24-2023)
1967 Pedal Car Champion
The GM Parts Wiki shows the following:
Do you have an AIM showing the assembly line part number?
I'm not sure what the antenna to radio vs. antenna to splitter applies to, but searching 22010551 brings up an eBay listing for one. The Lead-in 22010205 also shows an eBay listing.
RickM Z06 (10-25-2023)
I have a 78 AIM but at work now. Will look later. I did an ebay search for 78 cable with power antenna and got nothing. Didn't try the actual part #.
I looked at the AIM and is vague on the part #. Just shows 22009849 which is the antenna splitter and cable for the CB version. Anyhow, got a line on a replacement cable. Thanks all for the assistance!
I did notice that the drawing in AIM shows a power antenna and brackets that look way different than the replacement I got. Looks like I will be fabbing up some mount brackets this weekend. The originals are long gone and don't appear they would have worked anyway.
RickM
RickM
