Headlights made in the USA
As I get older, my night vision isn’t what it used to be. So I read this post with much interest: https://www.corvetteforum.com/forums...t-upgrade.html
I like these bulbs: Crystal Clear Version: https://www.octanelighting.com/5-34-...-g5-led-2.html
My only issue is they are made in China. I have not heard too many good things about China’s LED bulbs.
Any good USA bulbs? Need something as bright as above or brighter. Must be plug and play and work with stock wires.
The threads you referenced the best there is. Both Holley and Octane, you won't find any better made anywhere, thousands of satisfied customers. They are engineered in the U.S.A. None better (if any) are actually made in the U.S.A. It's like Sony TVs or Nikon cameras, buy what you need.
Dapper lighting….best stuff.
Projected output (through an engineered optic) not reflected like old school stuff.
You get what you pay for.
onaqwst (04-21-2023)
I put Holley Retrobright on my car. They’re pricey but they look like the old glass bulbs and they really light up the road. I hated to drive at night with those old dim yellow bulbs. I know there are a lot of comments about how bright led lights are but I haven’t had anyone flash their high beams at me yet. Do yourself a favor and get some new Holleys. They’re plug and play so no additional wiring is needed.
Looking at all 3 right now. Not sure if I want to go stock look or add the extra options.
Just ordered from Dapper since Holley was back-ordered till July
Just to continue this, my body shop recommend Sylvania SilverStar. But they seem to be only 1,000 Lumens.
I considered Octane as they are 4,000 Lumens.
The Holly retro brightright are 3,000 Lumens.
I am not looking at the recommend Dapper lighting. They are 3,000 lumens. But I am guessing all “Lumens” are not created equal.
Will the Dappers be brighter than the Octane even at less Lumens?
50 year old headlights use the parabolic dome at the rear of the assembly to reflect the light back out the front of the lens. Today with LEDs having a more compact directional light emitting surface, they can “direct” a higher percentage of the generated lumens through an engineered optic into a more efficient cutoff pattern.
Ever see your new Lexus headlight projected up against a wall or garage door? They’re is a level horizontal cut-off with a slight step near the center. This is because the optic isn’t throwing lumens up into space they are going exactly where they are needed.
When installed and adjusted properly, the Dapper headlights will have the same cut-off as your new car.
Have never used Holley’s stuff maybe they have great optics as well…..
Just because it has LEDs inside doesn’t mean it has good optics. Hence the $100 LED headlights throwing light every which way, appearing “too bright”, and blinding on-coming traffic (that and I’m sure most people throw them on the car and don’t properly adjust them).
cottoneg (04-22-2023)
Short answer.....No. Lumens can be measured with a light meter. The higher, the brighter the light. That's like saying a Honda is faster at 30mph than a Corvette at 40 mph. The lumen is a (universal) measurement of brightness, and the correct way to compare.
If I have an “omni-directional” a-19 LED advertised as delivering 800lm, and then look at say a BR30 down light LED lamp also advertised as 800lm, the BR with all of is lumens within just a 110 degree beam will appear much brighter because the delivered lumens are in a narrower pattern.
Same principle here, engineered optic that meets/exceeds DOT cut-off will put a much higher percentage of its initial lumens where they are needed. A crappy reflector/optic will waste up 30% of the lumens produce at the LED (diode) level.
Sorry this not true. You can measure Lux or Foot Candles which is intensity at a specific surface or point in space on a hand held meter. In order to get total lumens from a lighting system it needs to measured in an integrating sphere.................................. ..
That is true.
I know for sure that I would rather have 3000lm in a perfect cutoff pattern than 5000lm where half of them are lighting the sky or oncoming traffic.
Thats why when the OP asked for the best USA made headlights I recommended Dapper. I have installed (and properly aimed) 5 sets of these in my personal as well as customers cars (non-C3) and know how well they work compared to cheaper, less engineered products.
Like I said, have no idea how good or bad the Holley product might be as I haven’t tried them.
Just don’t buy headlights based on “advertised” lumen output alone.
That is true.
Thats why when the OP asked for the best USA made headlights I recommended Dapper. I have installed (and properly aimed) 5 sets of these in my personal as well as customers cars (non-C3) and know how well they work compared to cheaper, less engineered products..............
I just ordered the Holley Classic White.
I didn't feel like the Modern White would suit the look of the car for that year (1970), plus I didn't want to wait until the end of July. In any event, either one should definitely be an improvement with what's on now.
I drove the car last summer at night for the first time and it was an experience ..... had to really concentrate to see the road ahead. Pretty scary.
Lumens is really an awful way of measuring any kind of output. Manufacturers typically use the theoretical max lumen output of the LED chips which doesn't take into consideration optical (~20%) or thermal (~10%) loss. You often see 10,000- 50,000 lumen lights being advertised on Amazon. We've tested a 50,000 lumen against our 3,000 lumen bulb in our housings and seen higher lux on ours. Imagine the bulb is a motor and the housing is the vehicle. If you put an LS3 into a 40,000lb bus, it doesn't matter if it makes 500hp, it's still going to be slow... same concept with headlights.
Our lights theoretical lumen total is 3000 lumens but we use a rough effective lumen calculation of 2400. We see about a 20% optical loss from our testing (which is in CD).
Real optical testing is all done in CD anyway so lumen/lux is kind of irrelevant.
Regardless, please take all of the lumens/lux with a grain of salt. If they don't show you output photos, they are hiding something... Hope this helps!
Dementer sole survivor
Received 6,368 Likes
2016 C3 of Year Finalist
seen the octanes first hand...they are on my list.
If you really want to impress me, earn a (E1) ore (E4) mark for your lighting system. I'm not sure if that's even possible, although I've heard it's getting a little more in the realm of possibility for some European countries.
Of all the horrible LED "headlights" I've seen, those look to be the least horrible and least unsafe.
And to others on this thread, the danger from these headlights isn't so much the light you throw at oncoming drivers. That's annoying, but I've never witnessed an accident caused by that. The danger is the glare light thrown in useless places that actually reduces your night vision and makes it harder for you to avoid a single vehicle accident, where you strike an obstruction in the road or drive off the road because you can't adequately see where you're going. I've witnessed several accidents of that type involving a single car with horrible LED "headlights," including one where I was in the passenger seat when the vehicle struck a tree that had fallen across the road. And the body shop I use has gotten a lot of customer pay (not insurance) business from cars with LED "headlights" with damage from single vehicle accidents.
