427 oil pan question
So I recieved a 1968 Corvette 390/400 HP 427, complete, looks like it was in a boat. This is the pan that was on it, long sump with a baffle and other oil containment.
Is this a stock pan? I'm planning on putting it in a '68 El Camino, pretty sure I need a short sump for that. Any thoughts on what I have here?
Hans
Hans
Received 3,153 Likes
This is what my LS5 pan looked like, seems the same
M
M
You can see the drain plug in the back in the picture there.
Vettes were the only one to use the little trap door that I know of as well. Single step, 5 qt. I believe they had the same pan from 65 up to 74
M
M
1967 Pedal Car Champion
Dementer sole survivor
Received 6,388 Likes
2016 C3 of Year Finalist
Just did some quick searching and it should fit...I dont think there is any cross member interference
Just get the correct oil pump and pickup tube
Ecklers sells one that looks like a vette pan for the el camino
A original pan is worth a kings ransom these days if you can find one ,, im pretty sure they stopped making the repop ones too I have not seen one on ebay in a long time
one on ebay around $450
Vette5311 (02-03-2023)
I think Cranes had one for 650.00 but it’s gone now
Here’s my spare pan .. trap door and the drain slightly to the right and reinforced corners
Has a few dings but still in nice shape for over 50 years old
Received 6,995 Likes
2015 C2 of Year Finalist
your need a 65-72 Chvelle BB pan
Moose2000 (02-04-2023)
Interestingly enough, GM just stopped making the pan a year or so ago. I bought one ~2 years ago for about $220 directly from my local Chevrolet dealer. As I recall, the only difference over the years was that they dropped the spot welded corner reinforcements so you just bolted them separately.
Vette5311 (02-04-2023)
Mine was a little beat up on the bottom so I bought a new one through GM as well, that of course was back in 2014 so I'd better be more careful of those raised manhole covers all over the place around here
M
