1969 coupe weather stripping questions
I am finally at a point after owning my 427 435 car for 25 years now, to finally re do all the weather stripping. Ive done so much to this car as far as complete drivetrain rebuild riveted ball joints, rebuilt steering box trailing arms, bushings the list goes on. Lots of knowledge in that area, but never touched the weather stripping which is a bit of a grey area for me. So just wondering who or which vender sells the correct and best fitting rubber, as well as tips and tricks and don't do's. I want to do it right, although the car isn't a trailer queen by no means, just a driver. Its just that pillar rubber and t top rubber has all dried up and looks like crap.
I will say this regarding 1969 weatherstripping... The t-top weatherstripping changed at various points during production. Early cars used a two piece part... VERY late cars used a one piece part that was joined and is continuous (it's circular for lack of a better term). There is a third part that is used between these two parts that is also one piece, but is not joined and is linear in nature. The two ends come together at the front corner of the t-top when installed. Corvette Rubber offers the first two parts, but does not offer this interim part so be aware of that if you decide to order from them. I simply ordered the continuous part for my 1969 (even though it has this interim part) as you'll never see it with the t-top installed, it will definitely seal better than either of the other two styles, and even if you have your car judged, I doubt that there aren't more than a couple people out there that are aware of the difference in configuration.
Regards,
Stan Falenski
Bob K (02-02-2023)
