shifter console USB
shifter console USB
I pulled the shifter console today and the cigar lighter doesnt work, which is OK, since I dont think I will take up smoking soon. Which means that there is a power lead with nothing to do. Did anyone ever mod the lighter/ A.S.H. receptacle to be a power USB port and or a place for a line in?
Here is my saga..quality of parts matter…
you will also want to fuse the usb correctly
they also run in accessory now..lighter remains in case i need to start smoking again…
your lighter might just be loose if fuse ok
https://www.corvetteforum.com/forums...8-track-2.html
Bikespace (11-13-2022)
Do you have a newer radio in the car? Previous owner of mine installed a newer one and took the orange power wire for the cigarette lighter to power the radio since it needed additional power for radio station memory. I just spliced the wire so I could have it power both. So far no issues and I can charge my phone now.
Update: Reread and realized this isn’t what you’re asking for haha, but I’ll keep just in case it might help someone one day.
YMMV with an earlier car. I did almost the same thing @interpon did, and installed a 2-port QC 3.0 charger in place of the cigarette lighter. With nothing plugged in, the panel can close over it, and it has an on-off switch built in. If you don't have power to the red wire, trace it back and look for a bad fuse or other issue. Run a new ground to whatever you decide to install.
I found that a stepped drill bit made short work of the center panel hole enlargement. Something like this, though mine was likely from Harbor Freight.
interpon (11-13-2022)
The following 3 users liked this post by stingr69:
redcruz1120 (11-17-2022)
In my 72 I put one in the plastic cover in front of the console on the passenger side..Easy to reach and out of the way.
Here you go:
Here's the link to the one I bought (I have no affiliation with seller or manufacturer), but I'm sure there are other similar ones.
or 17 bucks and you have an A and a C and mine is also better because the voltage is higher...
bradleyb66 (11-16-2022)
