Need help!!!!
Cruising
Need help!!!!
I recently bought a 1970 corvette 454 4 speed T-top coupe. I am restoring it a little more and upgrading a few parts of the car. I will be doing a lot more as time goes on. I ran into a little problem seems the previous owner too the rear window storage tray out of the car. I found all the parts except one final piece need for the rear window storage tray. Below are pictures of the tray I was able to find. The part I need is the strike bracket that hold the tray closed. I is the bush bottom kind and does not have the wide black handle that says rear window storage, which is the only one I can find. So I need to know if any one else out there had a similar problem and what there solution was or where to find this last part. Or if any one has this tray pictures of the the strike bracket and measurements or a schematic so I can fabricate one? Any help you guys can give I would greatly appreciate it! I have pretty much tapped out my resources..... Help please!
Received 3,149 Likes
Does this help?
(I can take measurements if you need)
M
M
The following 2 users liked this post by Mooser:
georgetownsc (09-09-2022),
interpon (09-09-2022)
david howard. allc34me may have one.
Two places to try:
Richard Fortier 810-750-1472 richfortier@chartermi.net
David Sokolowski 310-329-5334
Both are NCRS members and may have the part you need
Kurt
Kurt
Cruising
Thank you for the pictures! I would need measurements if I had to make one. Another user on this site gave me a couple of numbers to call that might have the clip to sell me. If they don't have one or know where I can find one then I will get back to you on the measurements. And thanks again for the pictures that helps a lot!!!!
